Jagdtiger No.41 in Germany
Paul Sparkes
Has liked: 53 times
Been liked: 141 times
Re: Jagdtiger No.41 in Germany
Post by Paul Sparkes »
Sascha,
Very impressive work, I only hope my JT turns out half as good.
Do you know the thread size in the end of the barrel? I have modded mine for 140mm of recoil and just about to machine the other parts needed.
I don’t have the barrel here to measure and I want to design the mechanism.
Paul
Sascha Hornbach
Has liked: 383 times
Been liked: 468 times
Post by Sascha Hornbach »
I try to cast the Roadwheelhubs in tin with a oil sand mould and 3D printed master form. This is the first prototype and much room to improve the cast. Note that the tube has not the final length.
Paul, I am sorry, I do not know the thread size. I used that thread end to build the 140mm mod. I have no measuring gauge to check the size. Maybe Armortek could help here?
regards
Sascha
Sascha Hornbach
Today I made tasty Wheelhubs fresh of the oven...
I casted 18 hubs and drilled all the holes.
Then I CNC cut the brassparts, and cut off the old wheelhubs from the axles.
After drilling a 10mm hole in the axles, I put both parts together with Endfest 300 and tempered it at 100°C in the oven.
regards
Sascha
Oliver Brüninghaus
Has liked: 562 times
Been liked: 409 times
Post by Oliver Brüninghaus »
Mmm yummy, your wheelhubs look brilliant.
What alloy did you use for the casting :?:
regards
Oliver
It's Grim Up North
Has liked: 99 times
Been liked: 695 times
Those end caps look really great! Excellent!
Sascha Hornbach
Hi Oliver,
sorry for the delay, I do not use alloy, it is metallic tin. I do not have an oven who can reach the melting point of aluminium.
The last weeks I finished the elevation mechanism and mounted the endswitches. The Unit works now very smooth and fine. The electronic you can see is a controller for submarine piston tanks. So I can control the comlplete way proportional. A Video will follow soon.
Next step was to build the mechanic for the side movement of the barrel. I also use a gearmotor and endswitches. This weekend I make trials with the compressed air parts to get the adjustment for a scale recoil.
best regards
Sascha
Chang
Has liked: 14444 times
Been liked: 334 times
Post by Chang »
Hi Sascha,
How long is the leadscrew of the elevation mechanism? Customer-made or from Armortek?
Your modifications are really eyes wide open !
Lerh Chang
Sascha Hornbach
Hi,
the leadscrew has a length of 100mm plus the part without a thread with 20mm. The mechanism is my own mod.
best regards
Sascha
Oliver Brüninghaus
Hello Sascha,
your construction looks rock solid. No wobble is to be expected.
Brilliant solution.
Oliver
It's Grim Up North
Sascha Hornbach
Here a small trial Video:
Sascha Hornbach
Hi there,
not much time for big steps on 331, the last weeks I collected parts to build a 44` style control panel.
best regards
Sascha
Oliver Brüninghaus
Hello Sascha,
As always, you have done an excellent job.
Voltmeter, glow lamps and Pertinax give the perfect flair to match the model.
A real feast for the eyes. :-P
Best
Oliver
It's Grim Up North
Chang
Post by Chang »
Hi Sascha,
Do you have video to show how does the upgraded gun elevation work? How many degrees can it reach?
Lerh Chang
Sascha Hornbach
Hi,
yes I have a Video. I will post it next week, I am on a Submarine Meeting till Sunday. It reaches nearly the Original elevation angles.
Sascha
Sascha Hornbach
Here we go, not so easy to film and work with the Transmitter, I will make a new one in future.
regards
Sascha
