sdkfz 7 build log.
Been Liked: 480 times
sdkfz 7 build log.
Post by simon_manning » Mon Dec 24, 2018 12:42 pm
This is the start of my favorite Armortek vehicle, i have been looking forward to one of these builds for years, iv'e had one in the past but circumstances meant i had to sell, it's a 2005 kit with a few extras, i will add as much detail as i can and hopefuly turn out o.k., there have been some excellent builds on here for this vehicle so a lot to live up to, seasons greetings simon.
Michael Röder
Has liked: 18 times
Been Liked: 32 times
Re: sdkfz 7 build log.
Post by Michael Röder » Mon Dec 24, 2018 1:25 pm
Hello Simon!
I wish you much fun in modeling.
I'm already looking forward to the progress.
Greetings from Germany
Michael
Paul Wills
Has liked: 319 times
Been Liked: 104 times
Post by Paul Wills » Wed Jan 02, 2019 9:03 pm
Hi Simon,
I was thinking of starting my second Sdkfz 7 next, you may have put me off! I will be watching with interest though.
Paul. :wink:
Post by simon_manning » Wed Sep 25, 2019 10:33 pm
After not doing anything on my sdkfz 7, now i have started, only a small amount, i have spent time thinking about and collecting parts, i have a set of Michal Matata sprockets which are a work of genius, they are a complicated item to make and way beyond me even if i was in the mood to have a go, Tim Catton Rifle Rack clips and semiphore indicator arms which are also superb, i will post anything of interest, but this vehicle has been well covered, to a high build level, regards simon.
David Brady
Has liked: 4 times
Been Liked: 142 times
Post by David Brady » Thu Sep 26, 2019 1:03 am
Nice ingredients, I'll be watching looking for things to add to my build.
Those sprockets look superb....how did I miss these when they were being offered! I'f anyone has a set there thinking of selling please contact me.
Fabian Bekkers
Has liked: 99 times
Been Liked: 81 times
Post by Fabian Bekkers » Thu Sep 26, 2019 6:19 pm
Hello Simon I'll be watching your build closely have much fun of building I'll start next year.
Question sho made the turn indicators??
And rifle clips?? Are they still available??
Post by simon_manning » Thu Sep 26, 2019 7:00 pm
Thanks dave and Fabian, Tim Catton is the man you need for lots of SDKFZ-7 upgrade parts, He supplies, Dashboards, tools, all the clips and brackets, indicators, i will send over his e-mail, he is based here in the u.k. and his parts are superb. also steve winstone does upgrade work on these vehicles, cuts down build time because your thinking about the Jagdtiger kit coming, regards aimon.
Post by simon_manning » Sun Sep 29, 2019 5:47 pm
you have got to start somewhere so wheels it is, there's a small detail missing from the inner wheel's, a set of opening's, drill first then finish by hand, time consuming, one wheel every other day, to keep sane? regards simon.
David Brady
Has liked: 4 times
Post by David Brady » Sun Sep 29, 2019 6:49 pm
Nice tip simon....I will do this also just waiting for some drill saw rasp files to arrive
Post by simon_manning » Sun Oct 20, 2019 12:08 am
made some progress, finished adding some wheel detail and have assembled part of the chassis, i have to say these halftracks are a very enjoyable build, not to heavy and a change from a tank. regards simon.
Paul Wills
Post by Paul Wills » Sun Oct 27, 2019 8:12 pm
Hi Simon,
I knew if I left it long enough you would get started first :lol:
Great work with the wheels, are your wheels aluminum or the nickle ones and how long did it tke you to drill all of them out and file the slot?
Paul. :wink:
Post by simon_manning » Sun Oct 27, 2019 9:51 pm
Nice to hear from you Paul, i think they are cast aluminium, new drill bit's 3mm, oil, on my proxxon drill stand, one wheel a night, about 1 hour per wheel, then some hand fileing, helped with a small beer. i am enjoying the build a lot, it's different from a tank, and lighter. get your sdkfz 7 on the go, some more halfrack interest. regards simon.
Post by simon_manning » Wed Oct 30, 2019 11:02 pm
These Halftracks are a great build, simple but you have to be precise, the wheel clearence is close, i used some 7ba bolts to fix the wheels on for a more realistic bolt size, i never changed the bolt pattern at this stage, it might tempt me later, applied some base color on those hard to reach areas, its one of those kits you work out as you go, i like it. regards simon.
Post by simon_manning » Mon Nov 04, 2019 9:55 pm
A small update on the build for some winter interest. i made the front axle bump stops and trial fitted the wheels, i will get the chassis running first with the motor's and basic electrics, to see what adjustments are needed, regards simon.
Post by simon_manning » Thu Nov 14, 2019 8:20 pm
Fitted the main drive motor's and front suspension, made two leaf spring clamps and finished of the bump stops, all for now regards simon.
