Bergepanther William
Forum for discussion relating to the Bergepanther
William Gardeniers
Has liked: 13 times
Been Liked: 76 times
Re: Bergepanther William
Post by William Gardeniers » Sat Oct 06, 2018 5:37 pm
Thank you Bob and Fabrice.
Working on the aufbau the original from armotek have 4 hinged side panels in real it was only the right and left side.
rearside
leftside
With Regards William
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Wed Oct 24, 2018 12:37 pm
Hello
made a start with the steeltracks from Vincent. I would like to thanks Martin for his good drawings of the sprocket rings.
Rolf Mönke
Been Liked: 1 time
Post by Rolf Mönke » Thu Oct 25, 2018 11:06 am
Hello William,
a really great model !!
Greetings from Hamburg
Rolf
bosswilli-hh@gmx.de
Has liked: 870 times
Been Liked: 2360 times
Post by Phil Woollard » Thu Oct 25, 2018 4:00 pm
Looking good William, I love all your fabrication, regards Phil :D
Martin Hofmann
Has liked: 36 times
Been Liked: 484 times
Post by Martin Hofmann » Thu Oct 25, 2018 5:54 pm
Hi William,
thank you for the compliments for the drawings. I can see that the chamfers of the parts you have built are very small. Is there a possibility to come to the 5 mm and 15° seen on the drawing, because that is very important for finding the teeth to the track links! But all in all your Bergepanther is a very very amazing tank with so much details - i love it :D :D
PS: don't forget the distance plate of 1,5 mm between the ring and the body :!: :!:
Regards Martin
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sun Oct 28, 2018 4:18 pm
Hello
thanks for the comments . Martin the distance plate is mountet the chamfers on the teeth will come wenn the tracks are mountet and i can run it.
Made a new deckplate wich has the right openings .
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sat Jul 13, 2019 9:16 pm
Made some update's on the winch
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sun Jul 14, 2019 1:47 pm
Some small parts.
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sat Oct 19, 2019 4:55 pm
Made some small parts.
Gerhard Michel
Been Liked: 80 times
Post by Gerhard Michel » Sat Oct 19, 2019 11:43 pm
Hi William,
nice details, indeed!
Just a question: did you already get first knowledge with the steel track links when driving?
Gerhard
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sun Oct 20, 2019 2:33 pm
Hello Gerard
Steeltrack is on Hold i have mounted the distance ring i have chamferd the teeth off the sprocketrings. I have put a small distance ring between de tracklinks . The eisgreifer i brought back too 3 mm . But the big problem is the Horns on the tracklinks are too soft thy bend with only a little resistance. Have too figur out if thy can be harded.
So back to the original tracklinks .
Gerhard Michel
Post by Gerhard Michel » Sun Oct 20, 2019 10:08 pm
Hi William,
sad to read, but also my decision to go back to the originals. I had two severe stops when track links were jammed with bended guide teeth. Worse however was that the track links didn't follow the roadwheels when curving on rough grounds. Olaf grinded his chevrons down to 1 mm but they did not yet follow the road wheels when steering aside. Therefore I mean that the steel track links may be a nice decoration for a static display but are unusable when driving on rough grounds.
Gerhard
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Mon Jun 01, 2020 11:25 am
Hello
did some workon the Bergepanther
William Gardeniers
Has liked: 13 times
Post by William Gardeniers » Sun Jul 05, 2020 10:13 am
Made a start with the wood , from a good friend a got some real german oak boards.
I will use this number off plate's 8 there are also drawings with 6
Online
Marco Peter
Has liked: 237 times
Been Liked: 308 times
Post by Marco Peter » Mon Jul 06, 2020 12:37 pm
"...real german oak boards..."
Nice detail!
'Konan', my Tiger 1 Mid!
'Gunther', my Panther G!
