Tiger1 " tard-mid" !!??
Marco Peter
Has liked: 206 times
Been Liked: 305 times
Re: Tiger1 " tard-mid" !!??
Post by Marco Peter » Fri Oct 11, 2019 2:09 pm
Pure Pr0n!
'Konan', my Tiger 1 Mid!
'Gunther', my Panther G!
Been Liked: 395 times
Post by simon_manning » Fri Oct 11, 2019 5:33 pm
superb!, and thanks for posting, regards simonmanning.
Ivano Costantini
Been Liked: 447 times
Post by Ivano Costantini » Thu Nov 14, 2019 10:15 am
A change that I have not yet seen done by anyone.
My model (2010) has incorrect dimensions of the barrel and sleeve. I modified
the sleeve to lengthen it and bring it to the correct size. I also wanted to redo the most similar rod to the real one. I bought the FOA muzzle brake and this is the comparison with Armortek's. Neither of them corresponds to the measurements "Tiger1 info1". I think there were more types mounted on Tiger1.
Some canes had very visible codes
Ivano Costantini
Post by Ivano Costantini » Thu Nov 14, 2019 10:23 am
The sleeve has not been redone, only minor changes
Has liked: 239 times
Been Liked: 867 times
Post by Vince Cutajar » Thu Nov 14, 2019 12:19 pm
Great work as usual Ivano. I think the dimensions of the muzzle brake as shown on tiger1.info are for those fitted on early and mid Tiger1s. The late Tiger1s had a smaller and lighter muzzle brake which was actually the same as fitted on the King Tiger. I don't have these dimensions so do not know how smaller they would have been.
Could you tell me the width of those four grooves in the muzzle brake locking ring? I am thinking of making mine 1.5mm wide.
Ivano Costantini
Post by Ivano Costantini » Thu Nov 14, 2019 2:20 pm
Hi Vince,
If you refer to these, I made them 2 mm wide and 4 mm long.
A greeting Ivano
Post by Vince Cutajar » Thu Nov 14, 2019 3:28 pm
Grazzie Ivano. E quello che volevo. (Thanks Ivano. It's what I wanted)
Ivano Costantini
Post by Ivano Costantini » Fri Nov 15, 2019 6:53 am
How nice that someone tries to write in my language too!
Thank you very much Vince
Ciao! Ivano
Ivano Costantini
Post by Ivano Costantini » Tue Nov 19, 2019 6:25 pm
Hello to all,
have any of you built a tiger from the old Armortek production? I have this difficulty: my kit (2010) has supports for Armorpax replacement tracks. Once assembled, they look like this. Has it happened to you too? how did you solve the problem?
Thanks Ivano
Away from the turret wall
Away from the end of the hook
Marco Peter
Post by Marco Peter » Tue Nov 19, 2019 8:24 pm
Interesting question, I have the same problem!
Simon Peck
Been Liked: 20 times
Post by Simon Peck » Tue Nov 19, 2019 8:35 pm
Hi Ivano.
Will you not need that space for the zimmerit?
Simon
Ivano Costantini
Post by Ivano Costantini » Wed Nov 20, 2019 7:13 am
Hello Simon
too much space, it's more than 5 mm. the zimmerith must be much thinner, 1 / 2mm.
Hi Marco, have you thought about how to solve the problem?
Thanks Ivano
Marco Peter
Post by Marco Peter » Wed Nov 20, 2019 9:05 am
Not yet, didn't reach that point. ;-)
Steen Vøler
Has liked: 31 times
Been Liked: 163 times
Post by Steen Vøler » Wed Nov 20, 2019 9:11 am
Had the same problem and i decided to grind down the track link hight that are facing the turret wall.
This gives a ok look and is really not visible in my setup
cheers
Steen
www.panzerteam.dk
Ivano Costantini
Post by Ivano Costantini » Wed Nov 20, 2019 9:37 am
Hi Steen,
thanks for the reply but, the translator does not help me understand what you mean. Can you explain it better?
Thanks a lot and I'm sorry Ivano
