Armorteks next model
Jack Hrovatin
Been Liked: 18 times
Re: Armorteks next model
Post by Jack Hrovatin » Wed Oct 16, 2019 2:20 am
Sounds interesting, and how about a BMW Radial too for an FW190, or a large Pratt R-1830 as used on the P-47 Thunderbolt! As interesting as the Aviation theme sounds, the level of detail and need for accuracy exceeds Armorteks capabilities in my opinion. Building tanks with limited detail is one thing, but the finese necessary to do the aircraft detail well....is totally different. Armortek will build what they already have planned, surveys are fun, but don’t hold your breath.
Gerhard Michel
Been Liked: 54 times
Post by Gerhard Michel » Wed Oct 16, 2019 2:22 pm
An airplane- (or perhaps tank-) -engine may be nice, but it's higher if it is able to run, like a running tank model is much higher than a static display. My avatar shows a life running 14 cylinder double radial engine that fits an 1/6 scale airplane model. I intended to build a Gee Bee with it, but before this got true I changed from airplanes to tanks. The engine rotates a propeller of 40 inches diameter with 5,000 rpm.
Gerhard
Jack Hrovatin
Post by Jack Hrovatin » Wed Oct 16, 2019 2:27 pm
YES......How about the Continental R975 Radial to run the M4A1 Sherman tank.....two more items they’ll NEVER make!
Been Liked: 328 times
Post by John Clarke » Wed Oct 16, 2019 6:46 pm
Beautiful model Gerhard :mrgreen:
A model airplane rarely hits the ground "hard" tail first.
After my first and only excursion into the world of birds, on return that bag of bits was firmly sealed. :roll:
A single stick in one hand and a can/bottle/sandwich in the other. Large scale R/C modelling ambition..Tanks... problem solved. :lol:
Gerhard Michel
Post by Gerhard Michel » Wed Oct 16, 2019 10:20 pm
Hi John,
ok; may I make another proposal...?
(cat not included......)
Gerhard
Has liked: 163 times
Been Liked: 367 times
Post by Vince Cutajar » Thu Oct 17, 2019 3:11 pm
My wife says that you can keep the tank but wants the cat! :)
Brian Ostlind
Has liked: 403 times
Been Liked: 575 times
Post by Brian Ostlind » Thu Oct 17, 2019 3:32 pm
Is that leapord 1/4 scale?
epic
Robert Reid
Has liked: 46 times
Been Liked: 135 times
Post by Robert Reid » Thu Oct 17, 2019 4:07 pm
Either that, or it's a really small cat!!!
RPR
Chang
Has liked: 1661 times
Been Liked: 41 times
Post by Chang » Thu Oct 17, 2019 8:03 pm
Surely it is this one : (See the same cat :D ) Leopard 2 A7V beim RC Panzer Treffen in Hausen am Bach 2018
https://www.youtube.com/watch?v=6A5UvVNqJEI
Post by John Clarke » Thu Oct 17, 2019 10:17 pm
Hi Gerhard
It's a very nice cat.
The pussy's not bad either. 8)
Gerhard Michel
Post by Gerhard Michel » Thu Oct 17, 2019 11:16 pm
Hi guys,
the camouflaged cat is Reinholds Leopard II A7 in 1/4 scale, the other pussy is Peti, his tank commander. :mrgreen:
Peti is the only cat I know with its own tank crew beret (sorry for the blurry photo).
Gerhard
Has liked: 180 times
Been Liked: 53 times
Post by Christoffer Ahlfors » Fri Oct 18, 2019 9:09 pm
Nah, let's keep it 1/6. They are easy to carry around... :shock:
Gerhard Michel
Post by Gerhard Michel » Fri Oct 18, 2019 10:48 pm
In my proposal I meant the model type, not the scale.......... :wink:
For myself I can't use 1/4 scale because those models wouldn't pass the window of my basement, the only possibility for my tanks to enter or leave the room.
Gerhard
Derek Attree
Has liked: 45 times
Been Liked: 23 times
Post by Derek Attree » Fri Nov 01, 2019 2:30 pm
Hi Guys
For me it has to be a Universal carrier
found a couple of god you tube videos
https://www.youtube.com/watch?v=-nTsnfEAjzI
https://www.youtube.com/watch?v=g56HSVZlZ-0
Enjoy
martin pitcairn
Has liked: 133 times
Been Liked: 4 times
Post by martin pitcairn » Fri Nov 01, 2019 8:29 pm
Hi Derek,
great videos. Well found and posted
