Martin's Jagdpanther
Has liked: 239 times
Been Liked: 867 times
Re: Martin's Jagdpanther
Post by Vince Cutajar » Fri Jul 05, 2019 4:14 pm
It will be interesting to see how your recoil system develops. I can see you are using a linear bearing and toothed (timing) gears. Looks to be interesting. For my Tiger 1 I will be using most of the Armortek hardware but controlled by an Arduino and a stepper motor.
Has liked: 353 times
Been Liked: 849 times
Post by Stephen White » Fri Jul 05, 2019 6:29 pm
Martin, great to see your engineering skills. There is some film footage of the Weald Foundation Jagdpanther in action in my TankFest video on the TankFest 2019 thread. (See at 5.15 mins into the video).
https://www.youtube.com/watch?v=N0yq6vpZu98
With a linear bearing, you may well have to balance the gun barrel longitudinally. I found with my Cent linear bearing that any slight axial misalignment causes the barrel to jam in the bearing. I shimmed it to make sure there was no free play in the bearing and with the gun in balance, it now recoils very smoothly and freely. I'll be interested to see your experience.
Martin Hofmann
Has liked: 24 times
Been Liked: 426 times
Post by Martin Hofmann » Thu Jul 11, 2019 5:42 pm
Hi Vince,
hi Stephen,
her you can see the next progress of the recoil system with the new motors for barrel movement.
Maybe i forgot to tell you: there are 2 linear ball bearings in the parts with an inner diameter of 20mm and a distance to each of approx. 120mm. So i am sure there is no problem of jamming, because the rod has a tolerance of 20 -0.025 mm.
Regards Martin
Has liked: 250 times
Been Liked: 84 times
Post by Christoffer Ahlfors » Fri Jul 12, 2019 8:12 pm
I realize now that in order to fully appreciate this, I would need to know what it looked like before your modifications. :?
Either way, just watching your mechanics is pure joy! :D
Martin Hofmann
Has liked: 24 times
Post by Martin Hofmann » Tue Jul 16, 2019 5:08 pm
Hi Chris,
thanks for the flowers :D :D .
Here starts the chaos of the electric with all switches and the new 60W Benedini amplifier. It has a great sound after 2 hard weeks of working with all the cables, relais, power supply, aux module and switches ...............
Regards Martin
Post by Vince Cutajar » Tue Jul 16, 2019 8:27 pm
A very neat layout. Can't wait to see it in action.
Martin Hofmann
Has liked: 24 times
Post by Martin Hofmann » Wed Aug 07, 2019 4:38 pm
Hi Vince,
sorry for so long not answer, but i was very very busy first for Hausen and afterwards for job.
Here are some more progress - all without weathering
Regards Martin
Martin Hofmann
Has liked: 24 times
Post by Martin Hofmann » Tue Aug 20, 2019 5:04 pm
Here making some new recovery ropes and soldered with the tubes. After this i camfered the ends.
In the mean time the JP got some weathering. Now the red color is getting darker and is nearer to the origin in Bovingten.
Regards Martin
Martin Hofmann
Has liked: 24 times
Post by Martin Hofmann » Wed Sep 25, 2019 4:35 pm
Now all tools are mounted. Also the recovery ropes are on there place.
Only a little bit rust onto the exhausts are missing. That will follow soon.
Regards Martin
Has liked: 788 times
Been Liked: 2173 times
Post by Phil Woollard » Wed Sep 25, 2019 5:13 pm
Looking good!
Post by Vince Cutajar » Wed Sep 25, 2019 8:42 pm
Really well done.
Post by Christoffer Ahlfors » Thu Sep 26, 2019 8:10 pm
Perhaps I have said this before, but you are not only a first class engineer, you do the artistic part fantastically, too! :D
Been Liked: 395 times
Post by simon_manning » Thu Sep 26, 2019 10:00 pm
excellent martin, i like it, lovely job, regards simon.
Martin Hofmann
Has liked: 24 times
Post by Martin Hofmann » Fri Sep 27, 2019 3:50 pm
Hello guys,
thank you very, very much for the kind words!!! The compliments are always welcome. :D :D :D
Regards Martin
