Lucky to get an Sdkfz-222 - Looking for Advice
Leonard Rose
Post by Leonard Rose » Wed Sep 18, 2019 2:56 am
Picked up a built model that has the sound and drive modules installed. There is a connector labeled 24 volts. From search of this forum, found that the recommended batteries are two 12 volt 4.5 Ah units.
Have a couple questions regarding the installation of the batteries and hope to receive some assistance and advice. Due to the limited space, what has been for preferred locations and the means to mount the batteries. For charging, it would seem that it would be beneficial to charge the batteries in place rather than removing them from the vehicle.
Thank you in advance for any advice,
Leonard
mark lawson
Has liked: 1409 times
Been Liked: 161 times
Re: Lucky to get an Sdkfz-222 - Looking for Advice
Post by mark lawson » Wed Sep 18, 2019 7:46 am
The batteries are located in the front of the hull these go in through the turret ring then the body is attached to the chassis, once the chassis is attached to the hull its not possible to remove the batteries due to the gun mount, batteries are taped together for strength.
RAG Militärmodellbau
IG Militärmodellbau
Leonard Rose
Post by Leonard Rose » Wed Sep 18, 2019 8:24 pm
HI Mark
Thanks for the information, will need to remove the chasis and then wire a harness that will also allow charging the batteries in place.
Leonard Rose
Re: Lucky to get an Sdkfz-222 - Looking for Advice -Electrical
Post by Leonard Rose » Mon May 25, 2020 9:53 pm
Electrical Question
Have the '222 just about ready to go, have all functions except for the main motor operation. Have the batteries wired for 24 volt, the fuses are fine, have three lights operating on the main fuse box, and the throttle hold has not been set on the transmitter. Looking for any suggestions on what t check next.
Thank you in advance for any help or suggestions.
Has liked: 240 times
Been Liked: 365 times
Post by Adrian Harris » Tue May 26, 2020 12:30 am
Can you plug a servo into the receiver to check that the channel is working correctly ?
Which motion pack do you have ?
Leonard Rose
Post by Leonard Rose » Tue May 26, 2020 2:33 am
Hello Adrian
Plugged a spare servo into the receiver and it operated fine. Had not thought of performing that test.
The '222 has the following;
VTX-40-24
4QD DMR 203
Electronize 488-2W
Armortek 222 sound module
Armortek main fust / power unit with two fues (1) 40 amp and (1) 5 amp. Three lights that do operate and the main on/off switch.
Receiver has a separate on/off switch with a 4.8 volt nicad battery.
main power is from (2) 12 volt batteries wired for 24 volts.
Can provide photos if that would be helpful.
thank you for your assistance.
Leonard
Post by Adrian Harris » Tue May 26, 2020 5:05 am
One thing I recall about the 4QD set up is that you have to use the controller 1 ports if only using it with one VTX40, so Input 1 and Output 1 should be the ports in use for a 222.
If you're currently running it through the sound module, I would try it with the DMR203 straight into the receiver, to check that that works as expected.
The DMR input lead uses odd colours. The green wire is the negative, red is the positive and blue is the data connection. So the green wire goes to the same pins in the receiver as the black wire on Futaba colour coded cables and the brown wire on JR colour coded cables.
If it works directly but not when going through the sound module, then you have to make sure the inputs on the TBS5 are daisy-chained. This is explained on page 5 of the manual, which you can download here: http://www.benedini.de/TBS5E_5.pdf
Peter Silcock
Has liked: 38 times
Been Liked: 11 times
Post by Peter Silcock » Tue May 26, 2020 12:31 pm
Hello Adrian
VTX-40-24
4QD DMR 203
Electronize 488-2W
Leonard
Not related to your problem, but one thing I would suggest Leonard is to ditch the Nicad for the radio and wire in a 24v Battery Elimination Circuit. Turnigy do one for about £8 on ebay. Saves having to charge a radio battery and even if the 2 main batteries do lose charge there will still be enough to power the radio. I have always been a fan of the VTX 40 - shame they are not made anymore.
Leonard Rose
Post by Leonard Rose » Tue May 26, 2020 8:06 pm
Hi Adrian
Thanks for the info, have printed out the linked instructions and will review one evening this week. Will let you know what I find and will change out the receiver battery.
Leonard
