LAST SHIPPING DATE FOR 2019 WILL BE THURSDAY 12TH DECEMBER.
SHIPPING WILL RESUME ON THE 6TH JANUARY 2020.
Bergepanther William
- Has liked: 9 times
- Been Liked: 35 times
Re: Bergepanther William
Thank you Bob and Fabrice.
Working on the aufbau the original from armotek have 4 hinged side panels in real it was only the right and left side.
With Regards William
Hello
made a start with the steeltracks from Vincent. I would like to thanks Martin for his good drawings of the sprocket rings.
- Been Liked: 1 time
- Has liked: 546 times
- Been Liked: 1330 times
Looking good William, I love all your fabrication, regards Phil
- Has liked: 14 times
- Been Liked: 156 times
Hi William,
thank you for the compliments for the drawings. I can see that the chamfers of the parts you have built are very small. Is there a possibility to come to the 5 mm and 15° seen on the drawing, because that is very important for finding the teeth to the track links! But all in all your Bergepanther is a very very amazing tank with so much details - i love it
PS: don't forget the distance plate of 1,5 mm between the ring and the body
Regards Martin
Hello
thanks for the comments . Martin the distance plate is mountet the chamfers on the teeth will come wenn the tracks are mountet and i can run it.
Made a new deckplate wich has the right openings .
- Gerhard Michel
- Been Liked: 50 times
Hi William,
nice details, indeed!
Just a question: did you already get first knowledge with the steel track links when driving?
Gerhard
Gerhard
Hello Gerard
Steeltrack is on Hold i have mounted the distance ring i have chamferd the teeth off the sprocketrings. I have put a small distance ring between de tracklinks . The eisgreifer i brought back too 3 mm . But the big problem is the Horns on the tracklinks are too soft thy bend with only a little resistance. Have too figur out if thy can be harded.
So back to the original tracklinks .
- Gerhard Michel
Hi William,
sad to read, but also my decision to go back to the originals. I had two severe stops when track links were jammed with bended guide teeth. Worse however was that the track links didn't follow the roadwheels when curving on rough grounds. Olaf grinded his chevrons down to 1 mm but they did not yet follow the road wheels when steering aside. Therefore I mean that the steel track links may be a nice decoration for a static display but are unusable when driving on rough grounds.
Gerhard
Gerhard
