Chieftain Prototype Build
Has liked: 345 times
Been Liked: 734 times
Re: Chieftain Prototype Build
Post by Stephen White » Fri May 31, 2019 12:57 pm
Thanks Kian, good to know you're making good progress, despite the delays. If (when) you do have the prototype ready for TankFest, how about getting the Museum to have it do a short run beside the real thing? I'm sure we could arrange it if sufficient high vis jackets were worn.
Been Liked: 715 times
Post by Armortek » Mon Jun 10, 2019 9:59 am
Cast parts did not arrive on Friday as we had expected - looking like it will be this week though. Unfortunately that very likely does not give us quite enough time to get the parts scheduled for machining and built onto the prototype, so at this stage we are no longer planning to have the prototype at TankFest.
On the bright side - here are some photographs of the commanders cupola that we are just finishing off making. For the first time we will have clear acrylic periscopes on our kits as we continue to push the boundaries.
Been Liked: 389 times
Post by John Clarke » Sat Jun 15, 2019 11:15 am
Another first, acrylic angled periscopes,
With a little work, miniature mirrors, back light and a eye ball transfer.
Imagine :D
Dusk falls, the night is silent, there's a killer waiting in the shadows, a quiet click from the heavly camouflaged turret, a very slighty eery glow illuminates from the commanders forward periscope.
Two eye balls peer mercilessly into the cold dark damp air, a blink...... then...................
"Target acquired"
"Incorrect font, white boarder"
"Shoot!"
"Target destroyed" :lol: :lol: :lol: :lol: :lol: :lol:
Post by Armortek » Thu Jun 20, 2019 11:22 am
FINALLY IN ....
In the blue corner and weighing in at 16.95 kg, the prototype Chieftain Turret.
Now for a quick whirl on the 5 axis and then we are all done :-)
Feather weight
CIMG_6125 (854).JPG (114.99 KiB) Viewed 2233 times
Has liked: 666 times
Been Liked: 1784 times
Post by Phil Woollard » Thu Jun 20, 2019 12:13 pm
Now that's a lump! Looks the business too. It's a good job I frequent the gym init? 8)
Now just got to work on the other bicep
Post by Stephen White » Thu Jun 20, 2019 12:29 pm
Congratulations Kian, the result of a lot of hard work. It may not be obvious just what a complex shape each of these castings is on the real vehicle, as you discovered when you were measuring up the original. It's a pity not to have had the drawings available earlier but when these parts are set against the drawings, they will be extraordinarily accurate. It will be a unique and very impressive model. :D
Post by Phil Woollard » Thu Jun 20, 2019 1:08 pm
Thinking outside the box for a moment and considering the logistics of building and indeed owning and running this very impressive model, when we need to lift the turret, and this may be a two man job for some, even now with say the KT we use the barrel and the bustle as lift points. I'm sure you guys have already thought about a very robust gun elevation/depression mechanism because it's sure going to need one? 8) I can't wait to get working on this monster!
Maybe another consideration would be to keep the turret turn motor fixed to the hull and not fixed and so protruding from the bottom of the turret?
Kevin Hunter
Has liked: 48 times
Been Liked: 49 times
Post by Kevin Hunter » Thu Jun 20, 2019 6:33 pm
Parts look great Kian, will you please show them again post machining?
Bearing in mind the turret weight, and as most of us don’t have the luxury of a “Woollard” in our workshops, why not a 1/6 gantry crane.......? Just a thought :D :D
Post by Armortek » Thu Jun 20, 2019 9:57 pm
..... why not a 1/6 gantry crane.......? Just a thought :D :D
Actually It has been discussed Kevin. :)
We have no plans at the moment though as there will not be one version that suits all, but we are looking at ways to make handling and building heavy kits easier.
Post by John Clarke » Thu Jun 20, 2019 10:22 pm
The Official HSE lifting technique :lol:
Back straight legs bent. Keep the load close to the body for as long as possible while lifting. Keep the heaviest side of the load next to the body. If a close approach to the load is not possible, try to slide it towards the body before attempting to lift it. Avoid twisting the back or leaning sideways, especially while the back is bent.
Turret looks great :!:
Kevin Hunter
Has liked: 48 times
Post by Kevin Hunter » Fri Jun 21, 2019 10:58 am
Joking aside, I do have a hydraulic engine crane..... hopefully the turret lifting eyes will be up the job?
Post by Phil Woollard » Fri Jun 21, 2019 11:22 am
These electric workshop winches are not much money and will lift the whole tank if you want it to, just think about the ceiling joist fixing before you commit. 8) Most seem to hang from a 50mm scaffold pole quite happily, and just require a 13amp socket.
I use a slightly larger one to lift the shipping crate containing the tank onto the back of the pickup ready to be transferred to the carriers lorry.
This one is around £60 on the Bay.
Post by Armortek » Fri Jun 21, 2019 3:53 pm
Since we can't really show any progress on the turret yet .. how about the rear deck:
Post by Stephen White » Fri Jun 21, 2019 4:00 pm
Missing from this stage is the “T Piece” which I guess will bolt onto the decks. Looking quite superb, Kian.
Post by John Clarke » Sat Jun 22, 2019 7:23 am
WOW :shock:
