Jeffs 25 pounder
Jeffrey Goff
Has liked: 19 times
Been Liked: 133 times
Re: Jeffs 25 pounder
Post by Jeffrey Goff » Fri Feb 08, 2019 6:35 pm
Thanks for the kind words Stephen, yes I agree these gun kits are great fun to model and good value as well, I had some time today so made the elevation arm
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Thu Feb 14, 2019 4:22 pm
couple of small details added, the tangent-elevation engraving beside the cone, and the zero line marker board on the shield, also made a firing handle come safety for the blank firer.
I would love to engrave the curved lines on the sighting cone, has anyone an idea how to achieve this, i have left it blank so far, for fear of mucking it up
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Mon Feb 18, 2019 4:36 pm
made a start on the platform, there are a few things that I wanted to change, first i reversed the spokes so that the down angle was to the right, this ment filling the extra hole near the centre and drilling an extra hole near the rim, spokes are a temporary fit while I work on the platform, this has all been soldered together and rivets filed flat, one thing you rarely see on displayed 25 pounders is the degree markers on the platform, with a raised rivet head every 10 degrees on the top edge, so had a go to replicate this
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Sat Feb 23, 2019 6:28 pm
some more details added to the firing platform, toe plates and lifting hooks made and fixed, and all riveting done, just the 6 picket plates to make and fit
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Mon Mar 04, 2019 6:23 pm
hard to think I was enjoying the sun and walking on the beach in north west wales last week, all back to normal and on with the build, today I made the 6 picket brackets that rivet to the firing platform
regards Jeff
Has liked: 308 times
Been Liked: 1013 times
Post by Vince Cutajar » Mon Mar 04, 2019 9:08 pm
Amazing details. A labour of love.
Marcus Kwa
Been Liked: 38 times
Post by Marcus Kwa » Tue Mar 05, 2019 9:02 am
These photos just show that these 'kompact' kits can be as much a challenge and impressive as their larger (tracked) cousins!! Details are generally smaller but are in plenty supply all over the kit and: everything is visible.
Tugging at my leash to get building again....
Keep those parts coming Jeff!!
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Thu Mar 07, 2019 8:39 pm
Marcus, Vince thanks for the comments, most of the firing platform completed, put in the 10 and 5 degree marks, not sure if I need to mark the single degrees (288), added the lifting chains, but you do need the turnbuckles to lock the firing platform in the up position
regards Jeff
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Sun Mar 17, 2019 4:34 pm
It has been a few days since posting, but I have been busy trying to work out how to make the connecting arms, from the firing platform to the trail, these need to lock rigid when the gun is on the firing platform, unlock and fold while still attached to the trails,when raising to the locked up position, it took sometime to work out using photos, but I got there, I used and modified the arms from the kit, then made the central arms that have cam operated pawls that lock front and rear arms together, and a locking tab at each end, still needs to be cleaned up and painted, this should be the last of any major work the rest is window dressing
regards Jeff
Has liked: 390 times
Been Liked: 983 times
Post by Stephen White » Sun Mar 17, 2019 5:16 pm
Sunday delight. Exquisite workmanship. Thanks for posting Jeff.
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Wed Mar 20, 2019 6:42 pm
well I thought I had finished bashing metal, but realised I had not made the spade box, made from one piece of brass, shaped folded and silver soldered, hinged bolts with wingnuts riveted to the ends and the spacers added to the inside
regards Jeff
Has liked: 1046 times
Been Liked: 2807 times
Post by Phil Woollard » Wed Mar 20, 2019 9:37 pm
This will be one for "real or fake" probably the best example to date! 8)
Marcus Kwa
Post by Marcus Kwa » Thu Mar 21, 2019 8:10 am
I was impressed when I saw your shaped/angled reinforcement strips, but I am in awe with that spade box.. :shock:
Metal beating indeed!!
Marcus
Been Liked: 166 times
Post by Robert E Morey » Sun Mar 24, 2019 1:38 am
Jeff,
Excellent looking model! Its getting hard to tell yours from a real gun. Great work on all the bits! Takes a lot of patience!
Jeffrey Goff
Has liked: 19 times
Post by Jeffrey Goff » Wed Mar 27, 2019 4:23 pm
Phil, Marcus, Robert, thanks for the kind comments.
made a start on the various bits and bobs, started with the tool boxes, as the ones in the kit are solid alloy (good doorstops), I used wood and brass, and also used some fabric to simulate the water proof canvas around the lip of the lid
regards Jeff
