Helicoils
Simon Peck
Been Liked: 22 times
Helicoils
Post by Simon Peck » Thu Jan 31, 2019 10:03 am
Dear All,
I need to replace some of the helicoils in my suspension bars. Can you advise which make, type and size I need so as I can order the correct tools?
yves mouton
Been Liked: 121 times
Re: Helicoils
Post by yves mouton » Thu Jan 31, 2019 10:17 am
Hello Simon,
I also did replace some helicoils for my tiger 1.
I have a set from the brand Phantom size 1,5-D M6-1,0
If you buy a set the tools to place the coils are included.
I will post a picture later in the afternoon.
Best regards Yves
yves mouton
Re: Helicoils
Post by yves mouton » Thu Jan 31, 2019 10:28 am
Hello Simon,
Here is the picture of the Phantom set coils.
Best regards Yves
David Skeldon
Been Liked: 41 times
Re: Helicoils
Post by David Skeldon » Thu Jan 31, 2019 2:17 pm
Hi.
Never liked helicoils. Always found Time inserts by Width much better.
Simon Peck
Re: Helicoils
Post by Simon Peck » Fri Feb 01, 2019 9:21 am
Hi Yves,
Thanks for the reply. Did the Phantom helicoils fit without having to re-tap the existing holes? Do you have a source for them as I couldn't find after a quick search.
Kind regards,
Simon
yves mouton
Re: Helicoils
Post by yves mouton » Fri Feb 01, 2019 12:36 pm
Hello Simon,
You can take out the helicoil with a narrow pliers,
and if necessary you can re-dril the hole, but normaly if you can take out the helicoil
you dont need to re-drill.
The Phantom set i bought in my country: Belgium and the company name is Tollenaere.
Best regards Yves
