Barrel Sleeve
Dave Jackman
Barrel Sleeve
Post by Dave Jackman » Wed Jan 16, 2019 4:33 pm
Hi,does anyone know the locations of the barrel sleeve (oil?) plugs? Are there four or six?
Thanks.
Has liked: 365 times
Been Liked: 899 times
Re: Barrel Sleeve
Post by Stephen White » Wed Jan 16, 2019 6:15 pm
If you mean these on the Walzenblende, gun mantlet:
Tiger gun mantlet.jpg (243.23 KiB) Viewed 2874 times
ie two pairs at two and ten o'oclock but this appears to show one pair at twelve:
Similarly, Jentz and Doyle clearly show the ten and two positions:
Tiger gun mantlet 5 1.jpg (99.46 KiB) Viewed 2874 times
But they also show what appear to be different configurations:
so to answer your question, I'd suggest the answer is probably four, two pairs at two and ten o'clock. Given that the gun mantlet was changed in Nov 1942, to strengthen the gunner's eyepiece aperture, I suppose it's possible they changed from one pair at twelve o'clock to two pairs, to increase the circulation of lubricant. But that's speculation. You'd probably be safe with the two and ten configuration.
True Tiger rivet counting. There has to be a life somewhere.......
S
Kent Wiik
Has liked: 6 times
Been Liked: 73 times
Re: Barrel Sleeve
Post by Kent Wiik » Wed Jan 16, 2019 7:11 pm
Hi Dave and Stephen,
There was 6 screws placed 2, 10 and 6 o’clock in pairs and their purpose was to hold the ”Dichtung” in place.
There was also a drain hole at 6 o’clock.
Drawings here at David excellent tiger1.info site.
http://tiger1.info/EN/Mantlet-sleeve.html
The photo with the screws at 12 o’clock from the Bovington Tiger show the Britts replaced the sleeve upside down :shock:
Hope this helped.
It´s all in the details!
Re: Barrel Sleeve
Post by Stephen White » Wed Jan 16, 2019 7:15 pm
Kent, thanks. That explains the Jentz and Doyle diagrammes but how do you explain the second photo I posted which clearly has two screws at 12 o'clock. Was it possible to fit the sleeve upside down maybe?
Kent Wiik
Has liked: 6 times
Re: Barrel Sleeve
Post by Kent Wiik » Wed Jan 16, 2019 7:33 pm
Stephen,
Yes, the sleeve is by misstake replaced by her new owner, the Britts, upside down.
Please note the drain hole that can be sen in the photo, it is supposed to be placed at 6 o’lock or be useless....
Dave Jackman
Re: Barrel Sleeve
Post by Dave Jackman » Wed Jan 16, 2019 8:42 pm
Thank you very much Kent and Steven. That answers my question completely.
Kent Wiik
Has liked: 6 times
Re: Barrel Sleeve
Post by Kent Wiik » Wed Jan 16, 2019 9:04 pm
Ur welcome Dave, happy to help.
Sorry Britts I have to go down in flames here accusing you for assembling the sleeve upside down.
No the photo show the Aberdeen Tiger1 with its liftning lugs on the mantlet so it is the US who failed here, sorry.... :oops:
DAVE. Re: Barrel Sleeve
Post by Stephen White » Wed Jan 16, 2019 9:33 pm
You’re forgiven Kent. If it was upside down, mihjt have been Down Under. Hello Australia.... glad to help, Dave. Lots of other Tiger builders here. S
Has liked: 263 times
Been Liked: 397 times
Re: Barrel Sleeve
Post by Adrian Harris » Sat Jan 19, 2019 11:33 am
Anyone considering this addition, you will need M1.2 CSK slotted screws.
Mine have just arrived and I have no idea how to countersink a hole that small :lol: :lol: :lol:
Has liked: 265 times
Been Liked: 89 times
Re: Barrel Sleeve
Post by Christoffer Ahlfors » Sat Jan 19, 2019 9:34 pm
Drill a hole and hammer it in? :wink:
Re: Barrel Sleeve
Post by Adrian Harris » Sat Jan 19, 2019 11:10 pm
It wouldn't need a very big hammer :!:
Been Liked: 925 times
Re: Barrel Sleeve
Post by Vince Cutajar » Sun Mar 03, 2019 10:50 am
Adrian
Did you eventually find a way of making that small countersink?
Re: Barrel Sleeve
Post by Adrian Harris » Sun Mar 03, 2019 11:14 am
I've ordered one of these:
https://www.ebay.co.uk/itm/ALTiN-Carbid ... 3897149474
I'll post once it arrives.
Re: Barrel Sleeve
Post by Vince Cutajar » Sun Mar 03, 2019 11:16 am
That should work as it's got a sharp point.
Liam Mahoney
Been Liked: 18 times
Re: Barrel Sleeve
Post by Liam Mahoney » Sun Mar 03, 2019 8:19 pm
Hi Adrian
These go down to 1.3mm and are ok at 1.2 but they do burr the hole a bit so a quick clean up with the drill before you tap.
http://www.modellbauschrauben.de/index.php?m=03_44
Liam
