proportional smoke
Steen Vøler
Has liked: 32 times
Been Liked: 165 times
proportional smoke
Post by Steen Vøler » Sun Aug 26, 2018 8:12 pm
Hi all
Wondered if a sort of proportional smoke effect could be accomplished by wiring my 24v smoke fan to the motors - one at each motor power cables
The heat element is still wired to a on-off switch remotely controlled via my transmitter
Any thoughts here
cheers
Steen
www.panzerteam.dk
Has liked: 264 times
Been Liked: 397 times
Re: proportional smoke
Post by Adrian Harris » Sun Aug 26, 2018 10:03 pm
Steen, I thought you already had one of my smoker fan control units ?
There are a couple of problems when using the motor supplies.
1) Possible damage to the fan when running the tank backwards, as the voltage across the fan is reversed. You need a bridge rectifier to solve this.
2) There's no smoke output when the tank is not moving. There's no solution so this, other than using the smoker output from the Benedini board, as I do with my module.
Sam Hough
Has liked: 19 times
Been Liked: 8 times
Post by Sam Hough » Tue Aug 28, 2018 8:54 am
If you want to stick to pure analogue (I've got massive overkill solution with a raspberry pi) you would use a rectifier (as Adrian suggested) from the motors AND a drip feed from the main supply (resistor and diode) for idle.
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Tue Aug 28, 2018 1:30 pm
thanks Adrian and Sam
@Adrian - i did have one unit, but it was installed in my JP which is now sold :-)
cheers
Steen
www.panzerteam.dk
Post by Adrian Harris » Tue Aug 28, 2018 6:31 pm
In that case it sounds like you need another one :wink: :wink:
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Tue Aug 28, 2018 7:12 pm
do you still have one?
My new setup is Benedini Mini with 60 w amplifier.
Smoker is pure 24v, both fan and heat element
cheers
Steen
cheers
Steen
www.panzerteam.dk
Post by Adrian Harris » Sat Sep 01, 2018 8:30 pm
I always keep a stock :D Price is still 49ukp + P&P and paypal fees.
Email me at sales@armortekaddict.co.uk for a complete cost to Denmark.
