Marcus is correct in stating the elevation gearbox is too far forward, I moved mine 22mm to the rear, this ment moving and adapting the gear quadrant,
the bracket for the slew gear could have been moved rearwards but I did not want it on the bend of the trail, and it works well where it is, the elevation gear box now looks as it should
regards Jeff
