Panther A
- Has liked: 100 times
- Been liked: 695 times
Panther A
Der Alder ist gelandet - (The Eagle has landed). My Panther A arrived May 1. Not too much apparent damage from overseas transit.
The boxes are heavier than I remember...
The saga begins....
The saga begins....
- Has liked: 1528 times
- Been liked: 814 times
Re: Panther A
Hello Robert, exciting times, the Panther A kit is a work of art, and as you say big and very heavy. I have to be careful with my words, back in my day I could describe her more colourfully Looking forward to your build log. Best wishes....Mick
Re: Panther A
Colin,
That's a deep dark question. But use a good primer first - I prefer a red oxide color as this was most authentic for German vehicles. Some prefer gray primer.
I like the Tamiya TS-3 spray for the dark yellow, although at $6 (USD) for a small can -you will need a lot of cans to complete, it gets pricey. Some builders have had automotive shops mix up cans of the dark yellow color for them as well.
There are many dark yellow varieties including water based acrylics. Humbrol makes a nice spray color for the dark yellow as well, they call it "desert tan". But its also spendy for a 150ml can.
The camo for A's was dependent on unit, field of operations, and season of year.
Hello Mick, yes I'm sure anyone facing one in field had many choice words for sure! Thanks for the encouragement.
best regards all,
best regards all,
- Has liked: 2220 times
- Been liked: 6944 times
Re: Panther A
Hi Colin, before I bang on about paint, what are ur plans for the Panther?
Re: Panther A
New detail part coming soon for Panther A. Early type exhaust with cooling side pipes. Exhaust housing will be most likely 3D printed Nylon, The rest metal. Prototype parts printing now.
best regards,
best regards,
- Has liked: 122 times
- Been liked: 603 times
Re: Panther A
Hi David, thanks for the interest. I need to order the first printed parts in metal to check fits etc. It will be a bit more time. In the meantime I'm printing my own resin copy to show how it looks, fits together etc. More details to follow.
- Been liked: 52 times
Re: Panther A
Started work on the stamped steel wheels. Lots of trimming, deburring, priming, painting, bonding tires and of course hundreds of screws.
Machine ~2mm from rim of wheels:
I decided to replace the M2.5 screw with M2 on the outer facing wheels. Looks more scale.
Will keep the M2.5 screws on the hull facing side of the wheels.
Painted wheels with bonded tires (M2 bolts):
till next time,
till next time,
- Has liked: 239 times
- Been liked: 528 times
Re: Panther A
Very nice job on the wheels Robert.
So much better using the M2 nuts - think I will have a look at getting some for my Panther.
2022 Panther G #15
Re: Panther A
Quality work is nice to see!
