Yves Panther A update
yves mouton
Been Liked: 47 times
Post by yves mouton » Mon Apr 10, 2017 11:40 am
Hello,
Pictures coming soon
Regards Yves
yves mouton
Re: Yves panther update
Post by yves mouton » Mon Apr 10, 2017 9:32 pm
Hello,
Here are the first pictures of my panther
Tomorrow new pictures.
Regards Yves
Steen Vøler
Has liked: 34 times
Been Liked: 168 times
Post by Steen Vøler » Tue Apr 11, 2017 6:30 am
Hi Yves,
Its always good to start up a new build project :)
Happy building to you and look forward to see more pictures
cheers
Steen
www.panzerteam.dk
yves mouton
Post by yves mouton » Tue Apr 11, 2017 7:07 pm
Hello,
Here are some new pictures of the work on my panther.
Did a modefication on the gear, spacer rings for turret rotation, i drill extra holes
to put the rings together, so if i wanted to loose the turret i have only to unscrew the 6 wingnuts.
I also countersink the bolt in the rear deck.
I put the turret parts in primer and put them back together.
Also started on the turret roof and copula.
Regards Yves
Steve Norris
Been Liked: 251 times
Post by Steve Norris » Tue Apr 11, 2017 7:37 pm
Hi Yves
Looking good, the turret ring mod sounds a good idea
Been Liked: 144 times
Post by Robert E Morey » Wed Apr 12, 2017 6:43 am
Hi Yves,
She's looking great. Can't wait to get started on mine! Following your build with great interest!
yves mouton
Post by yves mouton » Wed Apr 12, 2017 8:05 am
Thanks you guys
8) 8) 8) 8)
Regards Yves
Maarten Schutjes
Been Liked: 1 time
Post by Maarten Schutjes » Wed Apr 12, 2017 4:44 pm
Impressive work Yves
Has liked: 981 times
Been Liked: 2615 times
Post by Phil Woollard » Wed Apr 12, 2017 4:49 pm
What a gorgeous little mill! You will be in the sh.t if she's sees her washing line being used as an outdoor spraying booth.
Good idea with the wing nuts , three would have been enough :D regards Phil.
yves mouton
Post by yves mouton » Wed Apr 12, 2017 6:41 pm
Hi,
Thanks for the good comments on my buid, Phil the washing line is not from my wife,but
from my mother so i dont be in trouble using that as a spray boot :D :D :D :D :D
Best regards Yves
Been Liked: 479 times
Post by simon_manning » Wed Apr 12, 2017 6:54 pm
nice to see you back on the forum yves, pleased with your long awaited panther kit, regards simon.
Been Liked: 835 times
Post by Armortek » Thu Apr 13, 2017 8:47 am
Hi all
The standard kit design of the new turret bearing on the new Panther is the same as that used on Tiger 131. The bolts go in from underneath , through the spacers, bearing ring and gear and a nut is fitted on top. To fit the turret simply lower it onto the projecting bolts and secure with the wing nuts. There are cut outs on the underside of the floor to clear the first nuts.
Paul Wills
Has liked: 284 times
Been Liked: 103 times
Post by Paul Wills » Thu Apr 13, 2017 10:22 am
Hi Yves,
Its great to see you busy building your Panther, I am looking forward to see your progress.
Paul. :wink:
yves mouton
Post by yves mouton » Thu Apr 13, 2017 6:34 pm
hello,
A few pictures, work on the scope covers for the copula,
with my mill machine.
Regards Yves
Steve Norris
Post by Steve Norris » Thu Apr 13, 2017 6:45 pm
Yves
Very nice, I will have to use a file on mine
