Muzzle flash LED test
Gerhard Michel
Been Liked: 78 times
Post by Gerhard Michel » Fri Dec 09, 2016 4:07 pm
Hello,
I would like to show you my test clip for a muzzle flash. I intended to get a bright flash with a slow quenching. This is reachable using an adequate capacitor which is pre-loaded before shooting to avoid strong currents through the electronic. Triggering and cutting (at the end) are made by relays, controlled by the shooting command (sound module). At this time I still experimented with the lighting period.
https://youtu.be/9TUYCzwbbfo
Gerhard
Has liked: 198 times
Been Liked: 307 times
Re: Muzzle flash LED test
Post by Adrian Harris » Fri Dec 09, 2016 8:14 pm
Looks very good Gerhard :D
What power of LED are you using ?
Sam Hough
Has liked: 16 times
Been Liked: 1 time
Post by Sam Hough » Fri Dec 09, 2016 8:56 pm
Indeed. I'm interested too as this bit is next on my todo list. I was just going to try darlington power amplifier.
Gerhard Michel
Post by Gerhard Michel » Fri Dec 09, 2016 11:50 pm
Hello together,
unfortunately my solution is already about 2 years old, and I cannot find the used LED again at my vendors. But I know it was a Luxeon StarHex LED with 1.6 watts in "amber". But I mean "yellow" or "warm white" would also fit; especially "warm white" with 3 or 5 watts.
Meanwhile I can say that the flash is visible also at bright weather conditions, looking at the front of the muzzle. Special cooling of the LED is not necessary.
Gerhard
Sam Hough
Has liked: 16 times
Been Liked: 1 time
Post by Sam Hough » Sat Dec 10, 2016 7:11 am
Hmmm. I've got 3 * 80mW. Might have to upgrade before even installed!
Picking one at random http://www.luxeonstar.com/cool-white-56 ... -led-235lm it takes up to 1A !?
Post by Adrian Harris » Sat Dec 10, 2016 7:44 am
The 5mm LEDs I used for the standard Armortek muzzle flash were 20,000mcd, which take about 50mA. Even 100,000mcd only take 70mA.
Check the bore through the barrel, as 88mm in 1/6th is 14.66mm, so you may find the bore is a standard 1/2" (12.7mm). Difficult to fit a 20mm diameter LED unless you take a whole load of material out of the muzzle brake. :roll:
Also consider the viewing angle. I think these muzzle flash units look best on guns with muzzle brakes, so that the LED is in the end of the barrel and reflects off the inside faces of the muzzle brake. To do that you need a reasonable viewing angle. 15deg LEDs will just push the light out of the end of the barrel like a LASER.
Gerhard Michel
Post by Gerhard Michel » Sat Dec 10, 2016 11:39 am
Well, these LEDs are also available in the type "emitter" instead of "star hex". Then the LED has only 7 mm core diameter (without pins) and fits propery to a bore in 1/6 scale.
My LED is used in the muzzle brake of an older BT King Tiger. There is space enough for a 20 mm LED ("star hex" type). In this position it lights the whole muzzle brake (no "laser" effect), but it is visible when looking from the side into the muzzle brake. The position is adjustable and a deeper impact is also possible. Here a pic:
Gerhard
Sam Hough
Has liked: 16 times
Been Liked: 1 time
Post by Sam Hough » Sun Dec 11, 2016 10:33 am
Thanks for sharing. I'll at least put in powerful enough electronics to drive one of these things.
http://uk.farnell.com/broadcom-limited/ ... dp/1718394
Is 3w and 4mm * 3mm * 2mm so should fit nicely.
Gerhard Michel
Post by Gerhard Michel » Sun Dec 11, 2016 1:47 pm
Yes, an nice flashing solution!
Here my "circuit diagram" :mrgreen: I use the 5 volts receiver voltage and some diodes to reduce it to the necessary LED power. A resistor "R" pre-loads a capacitor with moderate current. It powers the LED when activated by the relay. Resistor and capacitor may vary freely due to the used LED. The relay is triggered by the sound module.
Gerhard
Sam Hough
Has liked: 16 times
Been Liked: 1 time
Post by Sam Hough » Sun Dec 11, 2016 6:27 pm
Thanks,
The resistor and cap is a nice way to avoid inrush current and get the effect you are after.
I need to rewire mine a bit as I've routed the 5V supply for the turret servos too long as it is.
Sam
Sam Hough
Has liked: 16 times
Been Liked: 1 time
Post by Sam Hough » Tue Mar 07, 2017 6:00 pm
Hi,
I finally got around to buying an LED. Picture attached. I can't believe how small and bright it is!
It is on 3.5mm x 3.5mm and draw 1.5A at 3V... Not tested how hot it gets yet.
Got to do control circuit next ;)
Sam
