Can I change the sound unit
Steen Vøler
Has liked: 32 times
Been Liked: 165 times
Post by Steen Vøler » Wed Dec 19, 2012 11:43 am
Hi all
I bought a used JagdPanther and looking through the electronics I can see that the sound unit must be from the first productions, as it is not a Benedini sound unit.
The sound has some "noice" so I guess the sound box/amplifier is somehow not working correct. Would that be something that can be fixed
Alternative solution would be to make a change to the setup, so that I get the Benedini sound unit in the tank.
Would this be complicated to change?
Which Benedini sound module do I buy
Shall I only remove the old sound unit and reconnect the servo wiring? My thought was to connect the Benidini and a smoker to a seperate 12v battery.
Any suggestions?
cheers
Steen
cheers
Steen
www.panzerteam.dk
Has liked: 266 times
Been Liked: 397 times
Re: Can I change the sound unit
Post by Adrian Harris » Wed Dec 19, 2012 12:29 pm
Hi Steen.
Could you post a picture of your sound unit ?
How easy or complicated it is to fit a Benedini depends on whether the rest of your wiring is from Armortek or not.
Adrian
Been Liked: 797 times
Post by Armortek » Wed Dec 19, 2012 12:36 pm
Hi Steen
Armortek only ever supplied Benedini sound systems with Jagdpanthers. If you have
something else it must have been fitted by the previous owner, and purchased from another supplier. As Adrian said, post some pictures, and we can help.
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Wed Dec 19, 2012 12:41 pm
Hi Adrian
I have attached a pair of photos that I hope helps
cheers
Steen
cheers
Steen
www.panzerteam.dk
Post by Armortek » Wed Dec 19, 2012 12:50 pm
Hi Steen
Ok. The sound unit is an early Armortek type fitted with a Benedini sound card. You could upgrade to the Armortek Amplifier Module, that is the current system. You could re-use your existing Benedini card. The servo is completely non standard, and I can not see what it does. You don't need a servo for the sound system.
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Wed Dec 19, 2012 12:58 pm
Thanks Mark
How much would I need to pay for the new system
cheers
Steen
cheers
Steen
www.panzerteam.dk
Post by Armortek » Wed Dec 19, 2012 12:59 pm
Hi Steen
Contact Gill on sales@armortek.co.uk and she will let you have the details
Post by Adrian Harris » Wed Dec 19, 2012 1:47 pm
The servo looks like it's being used as a crude method to create a pair of RC controlled switches.
The switch it is resting against looks like it has had both connections cut.
You would need to follow the figure-of-8 cable from the other switch to see what it is actually controlling.
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Wed Dec 19, 2012 2:27 pm
thanks Adrian
Believe I need to do a rewiring of the tank to clean it up
cheers
Steen
cheers
Steen
www.panzerteam.dk
John Fitzsimons
Been Liked: 29 times
Post by John Fitzsimons » Wed Dec 19, 2012 5:54 pm
I had the earlier sound unit in my tiger and sent it back to armortek for upgrade with amp and twin speakers. Works really well now. Make sure you get the correct cables to connect new sound unit to older motion dmr203.
viewtopic.php?f=4&t=4770
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Wed Dec 19, 2012 7:21 pm
Thanks John,
That will most likely be my solution also
cheers
Steen
cheers
Steen
www.panzerteam.dk
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Thu Jan 31, 2013 9:15 am
So, I decided to go with the Armortek sound solution with the new speakers included.
really look forward to recieve it and get the sounds back into my JagdPanther
cheers
Steen
cheers
Steen
www.panzerteam.dk
Olaf Claus
Location: "South Front of Ruhrkessel" Siegen West Germany
Post by Olaf Claus » Thu Jan 31, 2013 3:51 pm
Hey Steen, your Japi well be soon roer proberly... :D
wat is with the Tank meeting by Reinhold Müller in Julie? are you comming?
regards Olaf
Steen Vøler
Has liked: 32 times
Post by Steen Vøler » Fri Feb 01, 2013 9:30 am
Hi Olaf
We are at the moment planning the summer vacation time and if there is no conflict with the travel, I will drive down to the meeting.
By the way - good news that you are coming to the Armortek day in September - I will be there with 2 friends, but without the JagdPanther as we are flying in from Copenhagen.
I really look forward to see your JagdPanther - it is looking fantastic :-)
cheers/Gruss
Steen
cheers
Steen
www.panzerteam.dk
Olaf Claus
Post by Olaf Claus » Fri Feb 08, 2013 10:20 pm
ok Steen , you see the jagdpanther on 13.07 and if all goes well you sse the jagdpanther on open days we come with models! provided that the customs officers opens the border... :D
cron
