Sarah's Panzer III build
David Gray
Post by David Gray » Wed Sep 01, 2010 7:28 pm
Hi Sarah , what strip did you end up useing for the casting seam on the suspenion arms
Brian Leach
Post by Brian Leach » Thu Sep 02, 2010 8:24 am
Sarah,
Clever, really clever!
And it looks good too.
Thanks,
Brian
Brian
Dennis Jones
Has liked: 8 times
Been Liked: 41 times
Post by Dennis Jones » Thu Sep 02, 2010 10:57 am
Hi Sarah,
Were you at Great Dorset Steam Fair with your Jeep ? Loads of military hardware there.
Dennis.
Sarah Frazer
Post by Sarah Frazer » Thu Sep 02, 2010 11:59 am
Hi Guys,
Hi David, the plastic strip I used was Plastruct 0.5mm x 1.5mm Styrene Strip, pack number 90723. The pack comes with ten pieces, though I only used three.
Thanks for the nice comments Brian :D .
Hi Dennis, I didn't get to the Great Dorset Steam Fair, the Jeep needs a little work to get it through the MOT and I'm not up to crawling under the Jeep yet. Looking forward to driving it again :lol:
Regards,
Sarah
David Gray
Post by David Gray » Thu Sep 02, 2010 7:34 pm
Thanks Sarah
Dave
Sarah Frazer
Post by Sarah Frazer » Fri Sep 10, 2010 10:20 pm
Hi Guys,
I've done more on my Panzer III :D
The suspension units are finished, they just need the base coat and fitting.
I've re-profiled the Road wheels and I'm glad they are finished. :)
As the second batch of the Panzer III's have had the inner part of the Road Wheel re-profiled, I have only re-profiled the outer edges.
I copied Stephen's idea of using a hub/carrier for the wheels.
I used a profiling tool to remove the 'step' section, giving it a nice radius like the full size wheels. To enable the tools to access the edge of the Road Wheels, I had to machine the far side of the wheel and run the Lathe in reverse.
Then I used a thread cutting tool to give the impression of a 'split rim'.
Then a bit of emery paper to round any sharp edges.
Now I need to cut lots of 4mm brass tubes........
Regards,
Sarah
Last edited by Sarah Frazer on Sat Oct 24, 2015 12:55 am, edited 4 times in total.
Has liked: 364 times
Been Liked: 890 times
Post by Stephen White » Fri Sep 10, 2010 10:52 pm
Looks great Sarah and you didn't have the joy of a form tool digging in doing the centre. They'll look good with your suspension units. Open Day is creeping up on us.
All the best.
Sarah Frazer
Re: Sarah's Panzer III build
Post by Sarah Frazer » Mon May 21, 2012 5:07 pm
Hi Guys,
Back with the Panzer III at last!
The Front Deck was ready to fit, but I didn't leave enough of a gap for the paint as one of the hatches is now catching.
I did a 3D CAD file for the Suspension Guides and had a set 3D printed. I was a little disappointed with the finish of the 3D printed parts, but a little filler soon gets the finish sorted.
Regards,
Sarah
Sarah Frazer
Post by Sarah Frazer » Mon May 21, 2012 7:48 pm
Below is another photo of the Suspension Guides, the grey one has had some filler applied to the blade and a couple of nuts have been place on to show how it will look when fixed to the hull. I intend to bond it and also use the two nuts to hold it on. The curved blade geometry is different to any of the book drawings, as the blade curve has been modified to suit the standard Suspension Arm placement and range of movement. Some others have moved the Bump Stops to a lower, more accurate, placement. However the area where I can use my Panzer III is quite rough and I don't want to limit the Suspension Arm movement. After using the Panzer III for a while I might investigate the amount of movement, before the Suspension Arms hit the Bump Stops, and then maybe lower the Bump Stops.
I also did a 3D CAD model of the Tail Light, which came out quite well. The front snaps on, so I can fit a working light inside. The Light is in the photograph above and the 3D model is below.
Has liked: 260 times
Been Liked: 395 times
Post by Adrian Harris » Mon May 21, 2012 11:27 pm
Nice looking parts Sarah :D
Interested to see you're keeping the "stock" suspension travel.
Do you think there's any danger that the arm will detach from the guide when it's unloaded ?
Sarah Frazer
Post by Sarah Frazer » Fri May 25, 2012 3:50 pm
Hi Adrian,
I have left enough room for the guide blade on the suspension arm itself, but at this stage I'm not sure i am going to fit it, the same as Stephen. It is worth fitting it on the hull side as this is the most visible, without any problems of what would happen when you get debris in the gap between the fixed and moving guides. Additionally I can leave a greater clearance, so there should not be any problems if it does get unloaded.
I did experiment with different versions of suspension arms and if I do put the guide blade on the suspension arms, I will cheat a bit and only have it sweeping over the front and side of the fixed part, rather than going to the front, side and the back of the fixed suspension guide. Also the guide blade on the suspension arm I will do in metal, the suspension guide on the hull being 3D printed in a polymer. If anything does go wrong and it gets damaged then a 3D printed suspension guide is less than £4 and can easily be replaced.
If I do decide to move the Bump Stop lower, when I have a bit more running experience with the Panzer III, then it's just a case of changing the blade geometry and getting another set 3D printed.
Regards,
Sarah
Luc De Weirdt
Been Liked: 4 times
Post by Luc De Weirdt » Wed Jul 18, 2012 7:37 am
Hi Sarah,
It's the first time I take a peek at your project and I must say that I'm very impressed. 8)
I'm sure that when this panzer is finished it's gonna be a real eye cather.
Gr. Luc
Sarah Frazer
Post by Sarah Frazer » Fri Sep 27, 2013 3:48 pm
Hi,
I've been updating some drawings for a small machine shop and managed to blag a bit of CNC time. So I have remade the Panzer III Suspension Guides I originally had 3D Printed in aluminium. They are an exact copy of the 3D printed ones and they took forever to machine, well not the five minutes I was expecting! :)
I'm still not sure about making the blade part that fits to the suspension arm, as it looks as though it is mostly obscured by the wheels. I'll have a good look at the panzer III at Bovington this weekend.
Sarah
