My Panzer III is on it's way
Sarah Frazer
Post by Sarah Frazer » Sat Aug 07, 2010 10:09 pm
Hi David,
I'm sure that I've read somewhere that the inside of the turret hatch doors were originally white, but out in the field they were painted the same colour as the outside of the tank. Otherwise the off-white colour stood out too much and made a good target. I'll go through a few books tomorrow.
The tank looks great :D
Sarah
Has liked: 177 times
Been Liked: 287 times
Post by Adrian Harris » Sat Aug 07, 2010 10:34 pm
I've read that somewhere too and it struck me that, if the tank was expecting to be fired upon, they'd have the hatches shut anyway.
If they weren't expecting to fired upon, then it wouldn't matter what colour the doors were...
Brian Leach
Post by Brian Leach » Sat Aug 07, 2010 11:25 pm
Hi everyone!
My books are about 1600 miles away, but I seem to remember that the first Pz III Ls were kind of a special limited batch, or so I gathered from the panzer tracts 3-3? I also seem to remember that they may have gone to N. Africa, that being true, could it be that the cast hinge is one of that limited batch and done up a little differently? It could have been. I have other pictures of that vehicle which show the scalloped, welded join flange for the upper and lower hull, so it was an early version most likly. (I think, I am afraid I am beginning to sound as if I know what I am talking about, which definately not true!)
Anyway, it seems the welded hinges are the common type, has anyone a Panzer Tracts handy?
Brian
Brian
Has liked: 339 times
Been Liked: 695 times
Post by Stephen White » Sun Aug 08, 2010 12:12 am
The original german engineering drawings of the side hatches in the Trojca book definitely show small welds around the side hatch hinges for all Ausf from L to N. Equally, they show no welds around the sehslitzplatter or vision ports. There are quite a few non-standard features on the Bovvy Pz III, so I wouldn't necessarily take it as a pattern. Original photos are really the best guide.
David Da Costa
Post by David Da Costa » Sun Aug 08, 2010 12:24 am
Yes I think the welds on the hinges are probably okay, conversely it looks like the welds on the vision ports are not and I need to remove them.
As to the white door interiors, it makes sense whkat has been said, but I imagine either way that after the tank being in action for a while that they would end up being chipped and covered in grime and smoke soot.
I think I will grime them up a bit more.
Interesting discussion.
David Da Costa
Post by David Da Costa » Sat Aug 14, 2010 1:45 am
While still working on the turret, I have started weathering the hull.
I am doing one "panel" at a time and have finished the left mudgaurd and now working on the rear.
I started with chipping and pain wear on the rear and first set of engine hatches and assosiated panel.
There is more to be done here and the paint wear and chips will be toned down slightly when I apply some dust and filters.
The next tank I will probably try the hairspray technique to do the chipping an paint wear.
Tim Bowman
Been Liked: 2 times
Post by Tim Bowman » Sat Aug 14, 2010 5:52 am
Hi David
Looks great! I can only imagine how nice your PIII will look when your weathering is completed. I don't know about using the hairspray technique, your chips look pretty darn convincing as they are on this tank.
Excellent job!
happy tanking
Brian Leach
Post by Brian Leach » Sat Aug 14, 2010 7:19 am
avid,
Excellent! I like the effect. It looks like wear.
I must say I agree with Tim, you are doing a good job.
I have seen the hair spray method.
On such a large scale it scares me. though you can
alwawy repaint.
I say too much!
I like what you have done. Thanks!
Have a good one,
Brian
Brian
David Da Costa
Post by David Da Costa » Sat Aug 14, 2010 8:09 pm
Thanks Guys!
Weathering is definitely one of those "arts" where knowing when to stop is the hard part.
I definitely think less is more in this case.
I think I just have enough of the RAL8000 left that I bought from www.kommiss.com who now seem to be out of business. I am not going to put a red oxide coat on the turret as it is much easier to cover the gray primer than red oxide, and this paint is hard to apply (takes many coats).
Looking forward to being done with this RAL8000!.
yves mouton
Been Liked: 41 times
turret texture
Post by yves mouton » Sun Aug 15, 2010 6:16 pm
Hi David,
I have a question about the texture you have made,
it looks very good. Can you explain wat product do you use and how you bring it on?
And do you put the texture on the bare metal?
Best regards Yves
David Da Costa
Post by David Da Costa » Sun Aug 15, 2010 7:32 pm
Hi Yves,
I have just followed the techniques used by others on this forum (thanks guys!)
What I do, is first I spray etch primer on the turret. You could put texture direct on the bare metal, but I think the primer gives a better surface for the texture to adhere to.
Before adding texture I give the primer a very light sanding, then I use Mr Surfacer 500 which I dab on in random areas with an old paintbrush. Then I wait for a few seconds for it to start to set and then dab it again with the paintbrush to raise some texture. Once it is dry, I sand the texture to flatten it out a bit, spray some more primer and look at the effect. I then repeat the process but this time adding fewer patches of texture, some on top of the previous texture, sand and re-prime. Remember keep it random.
I then sand it again to make the texture really subtle. re-prime and then I am done. You can keep repeating this process until you are happy with the look.
Remember that on the Panzer III the metal plate surface is a lot smother than the thicker plate on the heavy tanks so don't over do it. Look at the pictures of the Bovington Panzer to judge the amount of surface texture.
Hope that helps.
David Da Costa
Post by David Da Costa » Sun Aug 15, 2010 7:38 pm
I have now finished weathering the rear deck. As well as adding chips/scrapes to the rest of the deck, I also added some wear marks where the effect of sand and boots have worn through the RAL 8000 to reveal the german gray beneath. I have also add streaking on the rear of the tank to simulate where it has rained and washed dirt/ sand of the tank. I also added some oil marks where I imagine oily hands have held the engine covers, plus oil dropped on the rear deck when topping up etc. Also a considerable amount of oil around the armored started handle cover. (this is based on the photo on page 33 of Panzer Tracts N. 3-3).
Last edited by David Da Costa on Mon Aug 16, 2010 3:18 pm, edited 1 time in total.
Brian Leach
Post by Brian Leach » Sun Aug 15, 2010 10:28 pm
David,
This is going to be beautiful when you are done!
Brian
Brian
yves mouton
turret texture
Post by yves mouton » Mon Aug 16, 2010 8:11 am
Hi David,
Thank you for the info, the only problem is in Belgium i cant find mr surfacer 500, i know that Tamiya have a liquid surface primer maybe that gives the same texture, that i have to find out.
Or maybe i can use a dremel tool to make the texture, i dont know for the moment wat i'am gonna use
Best regards Yves
Tim Bowman
Been Liked: 2 times
Post by Tim Bowman » Mon Aug 16, 2010 1:29 pm
Hi Yves
The Tamiya version of the surfacing primer works as well as Mr Surfacer. I've used both and they are essentially the same. Tamiya's seemed thicker.
Hope that helps
