Sherman M4A3E8 76(w) HVSS Prototype
Been liked: 1082 times
Re: Sherman M4A3E8 76(w) HVSS Prototype
Some progress on the Sherman prototype. Parts are all coming together nicely - some have veeeery long run times on the machines.
Sherman z5.jpg (98.26 KiB) Viewed 1533 times
Sherman z4.jpg (77.93 KiB) Viewed 1533 times
Sherman z3.jpg (77.02 KiB) Viewed 1533 times
Sherman z2.jpg (73.76 KiB) Viewed 1533 times
Sherman z1.jpg (111.04 KiB) Viewed 1533 times
Jerry Carducci
Been liked: 69 times
Post by Jerry Carducci »
Stephen White wrote:
Mon Mar 08, 2021 11:29 am
Armortek wrote:
Fri Mar 05, 2021 10:48 am
Our recommended radio of choice going forwards will be the Taranis x9d plus 2019
https://www.frsky-rc.com/product/taranis-x9d-plus-2019/
Umm.... Knowledge Base anyone? The X9D is a great radio for our models but the scope for screwing up OpenTx is considerable unless there's some simple guidance.
I've been experimenting, bench testing with my older Taranis (pre-2019) x9d to control the guts of my M3 Lee.
I'm using:
-2018 Taranis Plus x9d Tx ( using OpenTx 2.3)
-external XJT Tx module
-X8R receiver
-24v 24Ah LiFePo
I'm a old Mode 2 Tx user (since my earliest Futaba days in the 70's) setting defaults as AETR with my tank drive controls on the left stick- throttle and steering. I want to use the left stick for forward/ reverse and steering; it's how I've set up every tank I have.
I'm using Open TX Companion on a Win10 desktop to configure the Tx and model profile(s) via USB connection for this testing.
Modules I've attached so far are motion and sound with the focus of my tests being controlling the L/R drive motors and two geared motors
for turret functions. So far all is well mixing Rudder and throttle except some odd performance near neutral for main drive controls- one motor
insists on continuing running ever so slowly. I think I may have to implement some sort of compensating offset on the output definition or some sort of curve. Still fiddling with that. Other controls seem normal including fail safe settings (set to zero for channels 1-16)- I tested it by shutting down the transmitter with the receiver and modules still powered up and all motors came to a stop ( except for the rogue creeping mentioned above!).
I think that's about it. If someone has a profile they like that works well I'd appreciate comparing notes regarding your settings. If anyone wants a copy of mine I'm sure I could send a zipped backup of my definition as it is so far.
Has liked: 505 times
Been liked: 1208 times
Jerry, great stuff. In order not to hijack this Sherman thread, I’ve copied your post to a new OpenTx thread in the Knowledge Base:
viewtopic.php?f=33&t=8585
Roy Beukeveld
Has liked: 139 times
Been liked: 83 times
Post by Roy Beukeveld »
Very impressive model! I really love the volute spring bogies, they look absolutely amazing 8)
Kind regards,
Roy
A few more prototype photos to see us into the weekend.
Sherman a15.jpg (84.66 KiB) Viewed 1186 times
Sherman a14.jpg (84.71 KiB) Viewed 1186 times
Sherman a11.jpg (102.48 KiB) Viewed 1186 times
Sherman a10.jpg (92.91 KiB) Viewed 1186 times
William Vallejo
Has liked: 17 times
Been liked: 2 times
Post by William Vallejo »
Talk about the quintessential torture master. You do know how to churn the anticipation.😈
William Vallejo
Has liked: 17 times
Been liked: 2 times
Roy Beukeveld wrote:
Sun Mar 21, 2021 10:51 am
I must agree. Not only was the HVSS a great improvement, I think it’s visually more pleasing to the eye.
Some more pictures of the prototype. We ill swap out the hex heads on the light guards to button heads to make them a bit more subtle.
Tank looks so much better with the tracks on - although the tracks are not on right as the sprocket is loose and some of the rubber tyres are not on the model.
Shipping is currently looking like it will be end of May/ Early June. We are very much in the hands of suppliers at this stage - all of the machining that we can do will be finished next week - we then need to sit pretty and wait for the tracks, castings and tyres ... and the driven gear which is now 8 weeks overdue :evil:
Still - that will give us plenty of time to test out the new elevation mechanism for this model.
Tim Page
Has liked: 25 times
Been liked: 141 times
Post by Tim Page »
That is really coming together nicely.
It is a shame that the headlight guards have to be bolted in place when they were welded on the original tanks.
Could you not have the legs locating into holes and then epoxy in place.
This would look a lot more realistic and would still be secure.
So far everything else looks spot on and really well detailed.
2008 Armortek Panther ausf.G #0035
2009 Armortek BefehlsPanzer 111 ausf.J #0011
William Vallejo
Has liked: 17 times
Been liked: 2 times
Tim Page wrote:
Thu Apr 08, 2021 11:34 am
A very good precision welder could possibly accomplish this.
William Vallejo
Has liked: 17 times
Been liked: 2 times
William Vallejo wrote:
Thu Apr 08, 2021 11:59 am
Never mind. It appears to me that the light guards are steel.
Jerry Carducci
Having the Easy Eight is going to be sooo cool...
Little update on the easy eight.
Only parts left to make - apart from the two castings - are the top armour inserts, the front hatches and the loaders hatch. The rest is all done, so really it is a case of waiting for the castings to be able to finish off this model.
Castings, at least in the small volumes that we need them seem to take an inordinate amount of time. In fact we have already ordered all the castings for the Tiger 1 and in the next month will shortly be doing the same for the Hetzer.
Current estimate for the castings is that we will get them around the second week of May. We will then set to work machining them and then it is on to the packing and shipping.
Production for the Sherman is now pretty much done - just the machining of the (cast) turret and differential armour to go .... but still waiting for those to arrive. Will have an update on that in a few days.
In the meantime, packing of all the parts is in full swing and we have also been making the option pack mechanical parts. On the topic of option packs, there will be a few changes:
1. Elevation for the Sherman will be operated via a linear actuator rather than using a lead screw
2. Recoil will be operated by a servo - programmed for a fast recoil and slow recovery. The LED will also be programmed to only flash on the recoil movement and not on the recovery.
3. We will offer a servo set up to move the machine gun back and forth, along with an LED. It is unlikely that we will have machine gun smoke ready in time, but it should be able to be added at a later date.
4. We will offer LEDs for the front headlights.
And finally - below are some photos of the finished model. We should have some video of the tank driving around outside once we get some dry weather .... currently predicted for next Friday :shock:
Jerry Carducci
Kian why let wet weather stop you! Get muddy! You know we Americans and our tanks love the mud....not!
The good old Sherman slogged through some muddy fields I'm sure...
I'm pulling your leg- I never, well hardly ever run my models in the mud. They're hellish to clean - our local adobe mud once
it hardens..... well you'll understand why the Spanish built missions up and down the coast with it. Try hiking up the hill in it and it
will suck the best of boots right off your feet...
No, a clean tank is a happy tank... looking forward to this..
