Early Sherman elevation pinion gear missing
Tim McCarthy
Been Liked: 8 times
Post by Tim McCarthy » Mon Mar 04, 2019 3:36 am
G’Day
Getting my 1st Generation Sherman M4 back into full working order and need help on the following missing part.
In the turret there is a pinion gear that goes between the motor and the half ring gear teeth, for the elevation.
As per my photos you can see where it is situated.
I am after any info on this part:- size, dimension, any think that might help me find or make one if necessary would be greatly appreciated .
Has liked: 87 times
Been Liked: 110 times
Re: Early Sherman elevation pinion gear missing
Post by Adrian Harris » Mon Mar 04, 2019 7:50 am
According to the Option Pack manual, it's a 24 tooth 0.5 MOD gear from HPC.
https://www.hpcgears.com/pdf_c33/23.10-23.13.pdf
Looks to me like you need part number G0.5-24, but I would get confirmation from Armortek before shipping one to Aus :wink:
R.I.P Margaret I.L.Y
Tim McCarthy
Been Liked: 8 times
Post by Tim McCarthy » Tue Mar 05, 2019 12:51 am
Thanks Adrian much appreciated
Tim McCarthy
Been Liked: 8 times
Post by Tim McCarthy » Thu Mar 14, 2019 5:21 am
G’day
Have acquired the pinion gear.
I just want to confirm the elevation motor RPM, the current one is not the correct motor and it is driving at 70 PRM which we fear may be a bit quick. I’d be grateful for any feedback.
