JT in Germany
Peter Quambusch
Been Liked: 248 times
Re: JT in Germany
Post by Peter Quambusch » Mon Dec 21, 2020 8:11 pm
Tom Wittstock wrote:
Mon Dec 21, 2020 2:28 pm
Question for you, did the Jagdtiger require wider tracks then the King Tiger or were they the same as the King Tiger tank?
Thanks Tom
Yes, it´s the same track width. Actually, the tracks you see on the pics are KT tracks. The new At tracks are as shiny as the Stug tracks.
Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change :-)
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Mon Dec 21, 2020 8:13 pm
Chang wrote:
Fri Dec 18, 2020 4:29 am
Just thought of an idea for this "Too small" Jagd Tiger:
(1) Replace two speakers into the casemate, then
(2) Move two large batteries backward to the end of the hull, or
(3) Move one backward and the other one forward as much away from the casemate as possible.
(4) There should be enough space for other option packs.
It maybe worth trying :idea: ....
Regards,
Lerh Chang
Not enough space. A whole battery is in the way. In trhe rear, I only have "half" a battery space, and in the front, the battery is too wide to fit between the motors. Thus waiting for the LiFePo....
Brian Ostlind
Has liked: 605 times
Been Liked: 1181 times
Re: JT in Germany
Post by Brian Ostlind » Thu Dec 31, 2020 2:26 am
Thanks Tom
Same.
epic
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Sat Jan 02, 2021 1:45 pm
While waiting for the new batteries and exploiting a lull in the rain, I decided, though not finished yet, to take the cat out for a test drive... Enjoy:
Steen Vøler
Has liked: 49 times
Been Liked: 290 times
Re: JT in Germany
Post by Steen Vøler » Sat Jan 02, 2021 3:41 pm
It blends well into the forest Peter :D
cheers
Steen
www.panzerteam.dk
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Mon Jan 04, 2021 4:25 pm
Thx Steen, I hope we can test it in DK some tike this year!!
Peter
Chang
Has liked: 7104 times
Been Liked: 104 times
Re: JT in Germany
Post by Chang » Mon Jan 04, 2021 5:30 pm
How many kilograms is the big cat now, Peter ? She looks so beautiful !
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Mon Jan 04, 2021 6:39 pm
Thx Chang.
Cat´s not ready yet. Rough guess is about twice my weight :P :P :P
Haven´t had her on a scale, but my guess is about 160 kg at the moment. But will be aprox 20 kgs less, once LiFePo got installed.
Peter
Steen Vøler
Has liked: 49 times
Re: JT in Germany
Post by Steen Vøler » Mon Jan 04, 2021 7:17 pm
Hi Peter
This would be great if possible. We are going for a build day again on Saturday, where we are building the terrain structure, planting some trees and vegetation.
Will put up a couple of pictures. The driver platform is ready, so that a good overview of the battlefield gives a perfect driving experience
cheers
Steen
www.panzerteam.dk
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Tue Feb 09, 2021 9:57 am
While still waiting for the batteries....
Tigers in the snow... :D
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Sun Feb 14, 2021 9:16 pm
Battery finally arrived, thanks to Kees!! :D :D :D
Thus the work can be resumed...
Gerhard Michel
Been Liked: 145 times
Re: JT in Germany
Post by Gerhard Michel » Mon Feb 15, 2021 10:40 am
Hello Peter,
20 kgs are a lot of weight to spare, you will see. I got this experience also in my Jati and was very pleased about that.
Nice battery pack. It comes together with a BMS, I suppose?
A strong battery also needs a powerful charging device. In my models I use both types of battery packs, with BMS and without. Therefore I needed a charging device with balancer, and I chose the Junsi iCharger 4010 Duo with 2 x 1,400 watts charging power. It has a maximum charging current of 70 amps (hardly needed) and a balancing current of 2 amps, a strong value. Most of other balancers can handle only 1 amp balancing current or less.
Please keep in mind that this charging device needs a seperate power supply.
Gerhard
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Sun Feb 21, 2021 7:34 pm
Hello Peter,
Hi Michael,
Thanks for the advice!! All taken into account. A special charger came with the battery.
Peter
Peter Quambusch
Re: JT in Germany
Post by Peter Quambusch » Sun Feb 21, 2021 8:06 pm
On return from maintenance, a lone JT negotiates the woods....
... spotting an American Unit, moving into an ambush position....
...lurking....
...Americans ambushed and captured...
...but luck ran out, a few miles down the trail...
... right track climbed over the idled wheel...
.. but maintenance crew got to work at once...
... and march was resumed after a little while....
Brian Ostlind
Re: JT in Germany
Post by Brian Ostlind » Sun Feb 21, 2021 9:31 pm
Where is the tank?
epic
cron
