Has liked: 1132 times
Been Liked: 2960 times
Post by Phil Woollard » Sun Jun 14, 2020 12:30 pm
Thanks for the info, I think the warco wm 180 with dro would do the job, why is it that the model you want is out of stock?
That's the biggest stencil I have in stock but have just ordered 50mm and 60mm sets, they are expensive for what they are mind. 8)
Derek Attree
Has liked: 104 times
Been Liked: 39 times
Post by Derek Attree » Sun Jun 14, 2020 1:13 pm
Hi Phil
I have the Warco 250v with dro and it's a great machine over 2 years.
I have just had a WM 16vs milling machine with dro delivered as well and again it's great.
Hope this helps
Post by Phil Woollard » Sun Jun 14, 2020 2:29 pm
Derek that gives me confidence to buy knowing that you guys are happy with the make and models that you have chosen. 8)
Has liked: 412 times
Been Liked: 1084 times
Post by Stephen White » Sun Jun 14, 2020 3:51 pm
Phil, good advice I was given was choose your lathe and then buy one size bigger. Looks as though Warco have the 240B in stock and it's not that much more, certainly cheaper than the Sealey job:
https://www.warco.co.uk/metal-lathes/30 ... lathe.html
And no, I don't have shares in Warco or any commercial connection, much to the pity.
Post by Phil Woollard » Sun Jun 14, 2020 4:30 pm
That's got the bigger Chuck to, I've sent them a question regarding fitting dro to that model. 8)
Jeffrey Goff
Has liked: 19 times
Been Liked: 133 times
Post by Jeffrey Goff » Sun Jun 14, 2020 6:00 pm
Hi Phil, I have had the Warco 240 for over 10 years, only problem was to replace the carbon brushes in the motor, that’s the only time it let me down, it come with its own tool kit and change wheels
Regards Jeff
Post by Phil Woollard » Mon Jun 15, 2020 5:43 pm
I've had a busy but enjoyable day weathering the Chieftain . 8)
Has liked: 7 times
Been Liked: 215 times
Post by Robert E Morey » Tue Jun 16, 2020 1:24 am
Phil,
Just stunning on the detail and painting. I like how the tape peeled some of the paint - looks very realistic. If you do ground level photos it would be hard to tell your Chief is not the real deal. You seem to set the bar several notches higher on every build!
Ivano Costantini
Been Liked: 601 times
Post by Ivano Costantini » Tue Jun 16, 2020 10:04 am
Hi Phil, I see with regret that the engine has not yet arrived, this morning I had this information from the traceability system:
on day 7, the shipment left the Italian national territory and was taken over by an English postal operator for delivery.
However I think it's an international problem, I still haven't received the bolts ordered on May 26th.
Grazie! Ivano
Ivano Costantini
Post by Ivano Costantini » Thu Jun 18, 2020 8:18 am
Hi Phil,
this morning the tracking system tells me that the package is being delivered. Let's hope!
Thanks Ivano
Post by Phil Woollard » Thu Jun 18, 2020 9:17 am
I wonder if that means it is out for delivery today? It's so exciting! 8)
Ivano Costantini
Post by Ivano Costantini » Thu Jun 18, 2020 9:53 am
in consegna, translates "in delivery"
Ciao!
Post by Phil Woollard » Thu Jun 18, 2020 11:32 am
Had to basically paint the numbers by hand. 8)
Has liked: 333 times
Been Liked: 1029 times
Post by Vince Cutajar » Thu Jun 18, 2020 11:46 am
You've got a lot of time on your hand.
Been Liked: 722 times
Post by John Clarke » Thu Jun 18, 2020 12:11 pm
Frighteningly wonderful, 8)
