Shield looks good
As for the hammer, I as an "old" tank driver can assure you, the hammer is THE MOST OFTEN needed (and used) tool in a drivers arsenal... What would we have done without our Hammer 5000 (meaning 5 kg)....
Without it, the Leo II would not perform half as good...
Hello
I was not 100% happy with the first I did.
So try, try again. Made these with 0,5mm Brass.
I did use a hydraulic press to do them.
Now it will be cut and shaped according to the original, and put in place.
I had a nice weekend in my cave.
Some more work on the exhaust shields, abit more to do. Grind, grind and grind.
Next I will do the square washers to the bolts.
But we have a very nice hobby and understanding wives.
I am finally done with the starting block on my Armortek Tiger One late.
Had to redo a bit, made some mistakes first.
I've said it before, brass is a wonderful material.
Robert
