Turret Bearing Upgrade
Steve Stuart
Has liked: 77 times
Been Liked: 57 times
Post by Steve Stuart » Fri Feb 01, 2019 10:47 pm
The original upgrade, a nylon bearing:
Nylon Bearing
Having seen the new Tiger with a lazy susan annular bearing and been impressed by how low a turning force is required I have worked how to retro fit it to my Early Tiger.
Armortek Instructions Page 29
I needed to order from Armortek the Bearing CE2103, the Lower Spacer CE2173 and finally a new Gear Ring CE2409. The old gear ring does not register with the holes in the new bearing assembly, so in with the new! There was another spacer required to sit between the the deck and the Bearing CE2103, so I purchased off ebay a cheaper bearing of the same size as it was dismantled to use the outer ring as the spacer required. This is because a recess needs to be made to accommodate the depth of the Turret.
The first thing was to register the Bearing CE2103 on to the deck and drill through 5mm holes and countersink them to attach the bearing and spacer to the underside of the deck:
Bearing Attachment to Deck
holes
The next thing was to line up the bearing to the Turret, using 3mm drill bits as pegs in the old Gear Ring bolt holes, I drilled through the new Bearing to create location holes for the 5mm dome headed nuts that secured the stack of Bearing CE2103, Spacer CE2173 and Gear Ring CE2409:
Bearing Alignment
Bearing Alignment Dome Nuts
Turret Bearing Location Holes
The Turret Motor mount had a spacer block fitted between it and the deck to lower it and to allow for a change of position owing to the larger diameter of the Gear Ring CE2409:
Gear Mount Block
To secure the Turret Down I have fitted two Catches:
Turret Catch
The Spacer and Bearing needed the fore and aft edges filing down so that it cleared the deck support beams, otherwise the overall width was to great to fit in between. The height of the turret in the recess can be adjusted by adding washers under the dome nuts. All in all it turned into a straight forward job, and is a neat upgrade.
Turret Location Holes
Has liked: 253 times
Been Liked: 84 times
Re: Turret Bearing Upgrade
Post by Christoffer Ahlfors » Sat Feb 02, 2019 7:45 pm
Great modification - thanks for the description! :D
I particularly like the catches to hold the turret secured!
Simon Peck
Been Liked: 20 times
Post by Simon Peck » Sun Feb 03, 2019 12:04 pm
Super upgrade. If easy, why don’t Armortek offer it? Must surely be popular!
Steve Stuart
Has liked: 77 times
Post by Steve Stuart » Sun Feb 03, 2019 6:19 pm
Possibly because it is the sort of thing that Armortek leave to customers to work out for themselves, because they know it keeps us entertained working solutions out. The main thing is that Armortek will supply the parts to allow us to do these things under our liability. Who knows what each older model has undergone in terms of upgrades and changes, so you have to be prepared to adjust the recipe to suit! Anyway I am grateful to Kian and Monique in getting this upgrade onto my Tiger. I am prepared to add more if what I have written needs clarification, just send a PM.
David Battson
Has liked: 31 times
Been Liked: 28 times
Post by David Battson » Mon Feb 04, 2019 10:39 pm
Steve,
Well done for working this all out. It's really good to know that this conversion can be achieved without the need for major surgery to the original tank parts.
Has liked: 246 times
Been Liked: 878 times
Post by Vince Cutajar » Sun Apr 14, 2019 2:00 pm
Did you lubricate the bearing?
Steve Stuart
Has liked: 77 times
Post by Steve Stuart » Sun Apr 14, 2019 11:07 pm
Vince, I have not as yet lubricated the bearing, as and when I think I will use a dry lubricant such as TF2 which contains PTFE beads. I don't want anything greasy or liquid oozing from the bearing!
Post by Vince Cutajar » Mon Apr 15, 2019 7:08 am
Thanks Steve for the info. I have a can of silicone spray and was thinking of using that.
Been Liked: 762 times
Post by Armortek » Mon Apr 15, 2019 8:53 am
Vince, there is no need to lubricate the turret bearing.
Kian
Post by Vince Cutajar » Mon Apr 15, 2019 9:57 am
Thanks Kian. Good to know. As the body of the bearing is aluminium I was worried about wear but I will heed your advice.
