Brian Ostlind
Has liked: 521 times
Been Liked: 785 times
Post by Brian Ostlind » Sun Aug 18, 2019 3:15 pm
Smart decision to adjust tracks at the end of the build. I would do the same thing now.
epic
Has liked: 308 times
Been Liked: 1020 times
Post by Vince Cutajar » Thu Aug 22, 2019 2:56 pm
Been doing some things on the turret roof. Made the simulated flat headed bolts and a shallow groove for the weld seam.
For the bolt pattern, as no particular accuracy was required, I just drew the pattern in CAD and taped it to the turret roof.
Then using a pointed tool marked up the locations on the roof. Removed the paper and used a slot drill to make a very shallow flat-bottomed hole. Did the same for the gun travel lock. If there is an interest, I could upload the two drawings here in .pdf format.
Yesterday received the turret ventilator from East Coast Armory but I will be keeping it in reserve as I am attempting to scratch-build my own (fingers crossed) from the drawings I did earlier on.
andymusgrove
Has liked: 148 times
Been Liked: 69 times
Post by andymusgrove » Thu Aug 22, 2019 11:05 pm
Hi Vince
Loving your blog and work you’re doing is amazing
I would be very ingested in a copy of your drawing please.
Andy
Been Liked: 184 times
Post by Robert E Morey » Fri Aug 23, 2019 3:32 am
Vince I too am loving your progress. Those first "drives" are awesome - when she first moves like a tank!
Great details!
Post by Vince Cutajar » Fri Aug 23, 2019 9:29 am
Yes Bob, I have to agree.
Andy
I tried to upload the two drawings but it seems the forum does not accept PDFs. So if you want, send me a PM with your email address and I will send them to you that way.
Post by Vince Cutajar » Mon Aug 26, 2019 4:47 pm
Still slowly carving up a piece of aluminium to make my turret ventilator. It's slow going and I managed to do a minor mistake but should not be visible. If I don't like it at the end I have enough material to do another one which should be quicker as I don't need to think about setups and machining steps.
Lower part of ventilator
Still a lot work to do but at least the hardest part has been done..
Christoffer Ahlfors
Has liked: 321 times
Been Liked: 114 times
Post by Christoffer Ahlfors » Mon Aug 26, 2019 7:46 pm
Aaaah, scratchbuilding! The noblest art of them all! This is going to be a very fine ventilator! :D
Been Liked: 544 times
Post by simon_manning » Mon Aug 26, 2019 9:00 pm
This is where the Rabbit hole takes you vince, one thing leads to another, hey presto out comes a lovely model, well done, regards simon manning.
Post by Vince Cutajar » Mon Aug 26, 2019 9:13 pm
Thanks Christoffer and Simon.
So true, and this rabbit hole is like a bottomless pit (still going down).
Post by Vince Cutajar » Thu Aug 29, 2019 4:03 pm
Ventilator is basically finished. As I did not have any actual dimensions of the real thing I just eyeballed the dimensions from two close-up photos of the turret ventilator. Infact I did not follow all the dimensions I had from my drawings but some of them were changed on the fly. I guess I need to update my drawings.
Using broken 1mm drills to locate the top cover
It is made from two parts
A little cleanup required and blocking of unwanted holes in the top cover and then glueing both parts together.
Post by Vince Cutajar » Mon Sep 09, 2019 4:47 pm
The turret ventilator is finally finished. That took quite a while. It's true what they say that it takes 30% of the time to make the part and then 70% of the time to finish it.
I made it to be able to bolt it from below instead of glueing it. That's one off the list. Next on the list is the loader's hatch.
davidwilkins
Been Liked: 175 times
Post by davidwilkins » Tue Sep 10, 2019 10:03 am
Vince,
Stunning work, the weld detail just finishes it off. Well done.
Post by Vince Cutajar » Tue Sep 10, 2019 12:11 pm
Thanks David.
I redrew the ventilator in 3D and if you want I can send them to you but I suspect that your Tiger 1 uses the earlier ventilator.
davidwilkins
Post by davidwilkins » Wed Sep 11, 2019 9:33 am
Hi Vince,
I have had a quick look at some of the turret details last night and I think the turret ventilator on the late tigers is different to the early tigers. However I will keep your offer in mind when I get closer to this part of the build.
Post by Vince Cutajar » Fri Sep 13, 2019 3:44 pm
I have been measuring and scratching my head for a while now but finally started "actual" work on the loader's hatch. I will be using the Armorpax kit as in my mind it gives the best depiction of the hatch for a late Tiger 1.
The only thing I will be changing is the white metal hinge. I want to bolt the hinges from the bottom and I think tapped holes won't last too long so I am re-making them from brass offcuts I have lying around.
Still lots of work required on the new brass hinges but at least for now it looks to be working.
