John's Early Tiger 1
John Fitzsimons
Been Liked: 35 times
Post by John Fitzsimons » Thu Feb 18, 2016 12:34 am
Third Tiger to start. I know I should finish the other 2 first but would like to get this off to a start as otherwise I will loose some parts.
This is not a kit as such but rather some components I have gathered together. I have almost all important components other than Wheels and suspension. The vehicle will be made from a combination of old and new kits with whatever modifications are required to make it fit together. I picked up many of the parts at the last factory open day The turret is the old cast version. The hull is mainly new release parts. Aluminium deck and ready to accept the latest wheel and suspension set up. I have no hull floor at present so eiter make one up or get one alongwith wheels and suspension. I have a spare set of tracks unused that I picked up a few years back.
I will also add many of my own upgrades. New front mudguards already on and working on the rear. Cupola viewports almost ready so looking forward to upgrading that also. I even have a spare to work on.I have a couple of sets of the old rear deck grills but will need to make a new suport.
Here are some photos.
Missing side skirts. Intrested if anybody has a set lying around.
viewtopic.php?f=4&t=4770
Been Liked: 502 times
Re: John's Early Tiger 1
Post by simon_manning » Thu Feb 18, 2016 11:29 am
a nice kit coming together john, regards simon manning.
John Fitzsimons
Post by John Fitzsimons » Fri Aug 09, 2019 10:29 pm
I have moved on a bit with the early Tiger. Still missing some parts but new lathe and milling machine will help sort that problem.
Started on a turret floor. Need to order more tread plate.
Rear mudguards almost ready
Cupola and turret view ports ready to fit.
fitted.
New aluminium firewall and front deck supports added.
Full length floor added.
Last edited by John Fitzsimons on Fri Aug 09, 2019 10:40 pm, edited 2 times in total.
Been Liked: 156 times
Post by Robert E Morey » Fri Aug 09, 2019 10:34 pm
Excellent looking parts. Always good to see new posts from you.
John Fitzsimons
Post by John Fitzsimons » Fri Aug 09, 2019 10:45 pm
Mg mount is the old white metal version. It lacked the ring I believe holds the mg cover. I thought I would easily cut it on the lathe but when fitted in the chuck it was very irregular. Centred with 4 jaw chuck and got there in the end.
