Tiger 1 (Early Variant) 2004 #98 build
Graham Hough
Been Liked: 1 time
Re: Tiger 1 (Early Variant) 2004 #98 build
Post by Graham Hough » Mon Mar 21, 2016 4:20 pm
May be a silly question but I assume all the tapped holes around the circumference of the driving cog take M3 hex bolts and nothing else? Noting in the notes I have found.
Has liked: 281 times
Been Liked: 407 times
Post by Adrian Harris » Mon Mar 21, 2016 5:22 pm
When you say "the driving cog" do you mean the sprocket (CE0303) ?
I don't think fasteners are provided for these holes - they should be studs with nuts, as per Tiger 131:
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Tue Mar 22, 2016 9:26 am
Sorry I did mean sprocket. Thank you for the clear photo I will now buy M3 studding and M3 nuts, although I may forget about the locking tabs.
John Fitzsimons
Been Liked: 34 times
Post by John Fitzsimons » Tue Mar 22, 2016 3:09 pm
I think the later kits came with m2.5 sllot head screws and nuts.
Items available. See link to forum post.
viewtopic.php?f=4&t=4770
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Fri Apr 01, 2016 9:09 pm
Does anyone, please, know of a supplier of the mesh grills that were fitted over the engine grills for the early Tiger? Were these fitted in the factory or a field modification? They would help to hide the lack of (for now) engine detail .
By the way I do like the new release C8 Quad. Now I will need to save up for that.
John Fitzsimons
Post by John Fitzsimons » Sat Apr 02, 2016 10:24 pm
The later kits had etch brass grill covers. Gill might be able to supply a set. Need a set myself also.
Russ Clark
Post by Russ Clark » Sun Apr 03, 2016 6:26 pm
I HAVE A PAIR OF FRONT BRASS SCREENS BUILT THAT I AM NOT USEING IF OR INTERESTED?
RUSS
Russ Clark
Post by Russ Clark » Sun Apr 03, 2016 6:32 pm
I was just checking and field of armor tanks has them in stock
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Sun Apr 03, 2016 7:31 pm
Thank you Russ I have sent you a PM.
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Tue Apr 05, 2016 1:39 pm
Latest pictures of the slow progress. Most of my time has been spent on lowering the rear deck. Lots of fiddly but interesting work, well worth the effort.
John Fitzsimons
Post by John Fitzsimons » Thu Apr 07, 2016 12:31 am
Having lowered the rear deck did you also take some off the top of the rear armour to make flush. You then need to lower the exhaust armour covers and shrouds. Exhaust stacks can be left in original place.
Sam Hough
Has liked: 22 times
Been Liked: 8 times
Post by Sam Hough » Thu Apr 07, 2016 7:56 am
Looks good Dad,
I'm busy learning python and trying to work out where to put the computer. I think I'm getting one for free. People seem to have bought them then not known what to do with them.
I'm glad John is keeping your standards high ;)
John Fitzsimons
Post by John Fitzsimons » Fri Apr 08, 2016 7:56 am
I have to do another rear plate myself. I used a power file to reduce the last two.
Did you get square head bolts with your kit to fit the covers to the deck? If not, Gill can supply. It's worth sinking these a little further.
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Sun Apr 10, 2016 5:06 pm
Thank you John for your helpful suggestions.
Working on suspension now. Some say swing arms should be set at 40 degrees the manual says 45 degrees, anyone have comments? In the case of the 40 degrees is that from the horizontal or the vertical?
Graham Hough
Been Liked: 1 time
Post by Graham Hough » Sun Apr 10, 2016 5:11 pm
The later Tiger manual states 30 degrees from the hull floor - help please.
