sturmtiger build at last
Been Liked: 499 times
Re: sturmtiger build at last
Post by simon_manning » Mon Mar 19, 2018 10:49 pm
thanks adrian and jeff, i looked at meccano gears on e-bay and i thought they seemed expensive, have you an alternative in brass, or just keep looking,
thanks for the praise regards simon.
Has liked: 293 times
Been Liked: 981 times
Post by Vince Cutajar » Tue Mar 20, 2018 4:54 am
Have a look at these:
http://www.hpcgears.com/
Not sure about the prices though.
Post by simon_manning » Tue Mar 20, 2018 9:43 am
thanks vince that looks good, someone always knows, regards simon.
Post by simon_manning » Sun Mar 25, 2018 7:38 pm
the last of the crane posts, nearly there apart from the lifting ring and cable, not sure of the material to use for the cable, wire is not flexiable enough at this scale, i will see what the internet throws up, just some paint to apply and detailing left on this part, regards simon.
Post by simon_manning » Sat Mar 31, 2018 6:37 pm
thats about it, finished, all i need to do is make the handle, the shell clamp has a clever hinge set up or so it appears, a retainig pin is removed, the shell is placed in the seperated ring, replace the pin, and as the shell is lifted the hinge tightens the band around the shell, well thats how i think it works, the hinge in its design is to elaborate to be just a clasp, regards simon.
Bryan Brown
Has liked: 28 times
Post by Bryan Brown » Sat Mar 31, 2018 7:01 pm
simon_manning wrote:
Sun Mar 18, 2018 11:20 pm
i have roughed out the basics of the winch, it does work but needs more attention to detail, a tricky little item, i will look for some brass gears instead of nylon which i think would be better, all for now , regards simon.
Hi Simon
I bought a quantity of meccano gears sometime ago I think they are still in the garage if you let me know what you need I will have a look through them to see if I have any that you require@
Bryan
Post by simon_manning » Sun Apr 01, 2018 1:50 pm
thanks bryan for the offer, i thought about it afterwards, how many times am i likely to want to lift a shell in to the tank, proberbly never, the nylon cogs will have to do, the whole mechanism does work but i would have preferred brass, if i did it again i would plan it better, but builds gain a momemtum and for me it's best to keep it going, easy to get bogged down in to much detail, all the best simon.
Post by simon_manning » Sat Dec 08, 2018 12:28 pm
i felt i was time to revitalise the sturmtiger build, i am on the home straight, well as much as poss without going crazy, the barrel and elevation ball would benefit from some more detail added, it would be a long term project to replicate the interior, so near enough is good enough. the rifleing in the barrel will be the hard part. seasons greetings simon manning.
Derek Attree
Has liked: 65 times
Been Liked: 33 times
Post by Derek Attree » Mon Dec 10, 2018 8:54 am
Hi Simon
Another stunner.
Has liked: 380 times
Been Liked: 948 times
Post by Stephen White » Mon Dec 10, 2018 1:45 pm
Simon, I'm well overdue adding my praise to your stunning build. It's an education. I've just acquired a copy of Achtung Panzer No 6 on the Tiger and to my surprise, it's also got a good section on the big dustbin launcher. If you haven't got it and need any info, please shout.
All the best.
Post by simon_manning » Sun Dec 23, 2018 7:13 pm
Thanks all for the encouragement, All i have done is fit the lugs on the morter tube, fit the ball mount and start the painting, over christmas i will do a bit more to try and push the build on to finish!, seasons greetings simon.
David Brady
Has liked: 9 times
Been Liked: 175 times
Post by David Brady » Mon Dec 24, 2018 11:11 am
Looking good Simon, what a rare model these sturmtigers are! I can only think of a three more that have been built.
Great build log with lots of detail that will assist other builders for sure.
chris fry
Been Liked: 37 times
Post by chris fry » Mon Dec 24, 2018 4:15 pm
yes, the rarest armortek model out there to date, look forward to seeing the finished article simon,
jagdsturmtiger,
David Brady
Has liked: 9 times
Post by David Brady » Mon Dec 24, 2018 7:21 pm
Nice model Chris...you should of kept that one.
Post by simon_manning » Sat Dec 29, 2018 7:38 pm
yes that is a rare vehicle, will we ever se it again in public. this is the progress on the sturm rifleing, cut shim steel strip's and glued them to a flexible backing, rolled it around an aerosol can to get the shape, test fitted, tweaked, pushed and pulled till i was happy, glued the sleeve in and placed clips to hold, now the finishing to come, slightly darken the bore for that more gunmetal look but keeping the metallic finish. happy new year simon.
