Florians FAMO build
Has liked: 867 times
Been Liked: 2352 times
Re: Florians FAMO build
Post by Phil Woollard » Fri Apr 05, 2019 12:21 pm
Well I hope you do as it will be an impressive beast to be sure! I have a 540 bhp XKR which I love very much, although I could buy a new small car every year with the running costs! :shock: We must be crazy :roll:
florian rudolf
Has liked: 90 times
Been Liked: 295 times
Post by florian rudolf » Mon Apr 08, 2019 7:57 am
Oh nice Phil, an XKR convertible?
So I will tell you about the track links. The split pins from the kit are a bit too smal for my mind. The photos shows as best why.
I'll change to another size.
Post by Phil Woollard » Mon Apr 08, 2019 8:30 am
That's a better size pin Florian, I made the head loop a bit bigger on my build using very fine long nose pliers, I did notice that left as they are supplied it was possible to pull the loop right through the track pin hole if you were not careful.
Not convertible, "rag tops" are not good in our climate! :roll:
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Apr 08, 2019 12:21 pm
Tahts alos a solution Phil, but the split pin is so tiny that I fear it would break in action maybe.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Thu Apr 11, 2019 2:45 pm
Some other elecronic parts arrived... The main drive control have 100A and with a little modify it fits in the space under the drivers seat :D
Also one of the tracks I've finished... My goodness how long that track bastard is. - Its over 2m :shock: My biggest rack size was that tiny little from my StuG 8)
Post by Phil Woollard » Fri Apr 12, 2019 8:25 am
Looking good Florian, boy that is tight for space under the front seat but nicely done. Hows the dummy engine coming along? 8)
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Apr 15, 2019 8:30 am
Do not remind me of the dummy engine Phil. I started it but I did not move on. I just want to finish the technology and electrics, then it goes on with it.
Yes, it is just under the seat, but it fits perfectly. That's the way it should be. 8)
florian rudolf
Has liked: 90 times
Post by florian rudolf » Thu Apr 18, 2019 10:12 am
Hello Derek,
sorry my late answer. I hope this helps.
Dimensions in mm.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Thu Apr 18, 2019 10:15 am
Did some electrik work. - Its nearly finished. Next step is the loading area with the main switches and akku.
I've got all electronik parts under the seats :D :D
Derek Attree
Has liked: 55 times
Been Liked: 32 times
Post by Derek Attree » Thu Apr 18, 2019 10:37 pm
Hi Florian
Thanks for the sketch of the bonet cut outs a big help.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Fri May 10, 2019 12:10 pm
After a little problems, the FAMO is now running nearly perfectly.
Some signal disorder I have, but fortunatly I know a good elecronic spezi, so it will be run perfect at a meeting in Leipheim.
After that I can go forward to finish the loading area and make more details.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon May 20, 2019 3:12 pm
After my first driving test at home, now it goes on the road to the Fliegerhorst Museum in Leipheim. On 25.05. I hope the weather is fine, so I can make some photos and videos of the Famo at work.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Tue May 21, 2019 3:47 pm
Big FAMo an his little brothers... Nice Photo from Overloon
CP1150308 (1366).JPG (163.48 KiB) Viewed 3600 times
Been Liked: 416 times
Post by simon_manning » Tue May 21, 2019 6:46 pm
Florian i was stood at the same spot also taking a photo, proberbly no further than a meter from you. regards simon manning.
Post by simon_manning » Tue May 21, 2019 6:50 pm
The photo, regards simon.
