Florians FAMO build
florian rudolf
Has liked: 90 times
Been Liked: 296 times
Re: Florians FAMO build
Post by florian rudolf » Tue Nov 27, 2018 11:29 am
Hi Derek,
its Panzergrau from Revell
Derek Attree
Has liked: 55 times
Been Liked: 32 times
Post by Derek Attree » Tue Nov 27, 2018 8:07 pm
Hi Florian
Thanks for the information.
You are going to need a lot of those pots I think :shock: .
Been Liked: 117 times
Post by Robert E Morey » Wed Nov 28, 2018 1:20 am
Florian
Nice work removing the machine mark on the wheels -it looks great! That's a lot of grinding!
Enjoying these FAMO builds - fantastic rig.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Wed Nov 28, 2018 7:06 am
Hello Bob,
Thank you for the praise. The Famo should be something special.
Has liked: 870 times
Been Liked: 2355 times
Post by Phil Woollard » Wed Nov 28, 2018 8:40 am
Morning Florian, a question, should our Famo have the two top vents in the bonnet?
florian rudolf
Has liked: 90 times
Post by florian rudolf » Wed Nov 28, 2018 9:09 am
Yes Phil it have to tops, for front and loading area.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Wed Nov 28, 2018 9:14 am
@ all FAMO owners and screw interests, pleas note.
The special track links screws are availabal, but to thinks to note:
1. The delivery will be at latest in March 2019.
2. The price for 250pcs. would be 41,00€ + shipping.
So pleas note, if you want to get the set send me an PN or email:
hot.rod32@web.de
Chang
Has liked: 4767 times
Been Liked: 56 times
Post by Chang » Wed Nov 28, 2018 6:22 pm
Two top vents on the bonnet shown on someone's scratched-built FAMO.
(See http://www.sixtharmygroup.com/portal/viewforum.php?f=23)
florian rudolf
Has liked: 90 times
Post by florian rudolf » Thu Nov 29, 2018 9:56 am
Hi Chang,
thanks for your image. My plan is to build it like this. But unfortunalty its a long time to come to this piont. Maybe in Febr. I am on this point. In time lots of other work to do.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Dec 03, 2018 7:50 am
Good morning all,
a view day bevore I posted al little construktion problem. I'll be back with my solution.
You see at the attachments the bracket to fix the track mudget on front under the body bottom. The problem is, that you cant fix the mudget, because you can't hold the nut for tithening. So I take now M4 fasteners for tithening the mudget.
So I drilled a thread (M4) in the bracket, and make two other holes for M3 countersunk screws, to fix the bracket.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Dec 03, 2018 7:51 am
On weekend I worked on my winch. Its now finised. Photos comming soon.
Post by Phil Woollard » Mon Dec 03, 2018 11:19 am
Nice mudguard fix Florian, just make sure the tracks can't catch the cap heads, square head bolts and track links can stop a motor dead, especially when the road wheels suspension is at max deflection!
I get my winch end of next week so I will apply your fix to that also, keep up the excellent work regards Phil. :D 8)
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Dec 03, 2018 1:41 pm
Yes Phil I thought about that track problem... The screw is verry flat (looks bigger on the photo), so that will be work.
florian rudolf
Has liked: 90 times
Post by florian rudolf » Mon Dec 10, 2018 7:41 am
Hi guys,
it takes a little time to prepair the trackwheels, but now I could finish my trackwheel and framework... It looks good I think.
Making the fasteners for the outer wheels
All I need
Chang
Post by Chang » Wed Dec 12, 2018 12:02 am
florian rudolf wrote:
Mon Nov 26, 2018 10:42 am
Hello Famo owners,
I continued to work on the winch. here it needs some rework, so that the winch works well.
Hi Florian,
Regarding the re-work on the winch, what are the details of re-works? I have two questions here:
Question (A),
The CS0574 and CS0511 are together with the winch case here.
I am confused with the diagram in the manual:
(1) CS0574----One end with a M4x4 grub hole. Should it be on the left hand side of the hole in the winch case, or the other way around?
(2) CS0511----One shaft is shorter, and the other one longer. Which side should be into CS0574?
Question (B),
I've found that without CS0511, the shaft nut (CG0249) can easily be locked tight into the winch case. But became impossible when CS0511 is in position. Is there any re-work needed?
Sorry about the long words.
With regards,
Lerh Chang
cron
