Florians FAMO build
Has liked: 132 times
Been Liked: 38 times
Re: Florians FAMO build
Post by Christoffer Ahlfors » Tue May 21, 2019 8:33 pm
Clearly, you two must be the same person! :shock:
Been Liked: 82 times
Post by simon_manning » Tue May 21, 2019 10:17 pm
interesting Florian, where did you get the photo from, regards simon.
florian rudolf
Has liked: 72 times
Been Liked: 239 times
Post by florian rudolf » Fri May 24, 2019 12:16 pm
Hello Simon,
look at the post from Armortek at Militracks in Overloon.
Unfortunatly I have'nt been there at this time. Nex year I'll be there.
florian rudolf
Has liked: 72 times
Post by florian rudolf » Mon May 27, 2019 12:08 pm
The first roll out.
I remember some problems at my Sdkfz251. The same I have with the FAMO.
I have to do some work at the track. Also some electrik problems, but nothing difficult.
Has liked: 436 times
Been Liked: 886 times
Post by Phil Woollard » Mon May 27, 2019 3:06 pm
So nice to see your Famo out in the sunshine, she's looking good 8)
Email; magpiespyro@hotmail.com
Chang
Has liked: 738 times
Been Liked: 33 times
Post by Chang » Mon May 27, 2019 7:45 pm
The first roll out.
Hi Phil,
The FAMO looks good.
I reckon two 12V batteries were laid on the cargo area. Is there any photo of them?
With regards,
Lerh Chang :D
florian rudolf
Has liked: 72 times
Post by florian rudolf » Tue May 28, 2019 7:41 am
Hello Chang,
I make another solution with the battery. In one of the stowage boxes are the switches, the other one get the 'original' inside... 8)
florian rudolf
Has liked: 72 times
Post by florian rudolf » Tue May 28, 2019 7:43 am
Thanks Phil,
yes it looking good outside... - It gives me a push to do something on the FAMO to finish this year :)
Chang
Post by Chang » Tue May 28, 2019 8:22 am
Hello Chang,
Hi Phil,
Thanks for the reply.
Not sure if I misunderstood your meaning. How are two of 12V batteries able to be squeezed into the other storage box? :?:
Regards,
florian rudolf
Has liked: 72 times
Post by florian rudolf » Tue May 28, 2019 9:48 am
its only one 12V akku each stowage box. This are smale LiFePo accus I think. With only 6 or 7 Ah.
I want ti install an 24V / 12Ah accu.
Florian
florian rudolf
Has liked: 72 times
Post by florian rudolf » Fri May 31, 2019 8:11 am
I had some time to build a little more details on my FAMO.
so I made the frame for the drivers seat, and while having a good friend is saddler, I've got some thin leather in the right color for the poetry between the fire panel and hood...
florian rudolf
Has liked: 72 times
Post by florian rudolf » Fri May 31, 2019 8:14 am
At my first roll out I noticed some problems with the track. The same I had with my SdKfz 251. So I have to modify my track a bit.
florian rudolf
Has liked: 72 times
Post by florian rudolf » Tue Jun 11, 2019 10:12 am
Some more details finised and fixed at the model.
If my modified tracks are complete and at work, I'll make some photos of that.
florian rudolf
Has liked: 72 times
Post by florian rudolf » Fri Jul 05, 2019 7:40 am
A little work on the fenders. I milled the alu at the middle section so it looks some more scale. The weight I lost at this position I'll put later into the engine dummy. You need the weight because the steering function on slippy bottom.
florian rudolf
Has liked: 72 times
Post by florian rudolf » Wed Jul 10, 2019 8:32 am
Some work on the loading area and fenders.
The fenders instalation is quite difficult, because a long part with some fasteners to fix. - So if one part does'nt haf the rigt position in a bit of a mm, you can't get it fixed.
Now my loading area and fenders come together on the famo and looks amazing. :D
