Page 5 of 9
Re: Jeffs 25 pounder
Posted: Mon Jan 14, 2019 4:10 pm
by Jeffrey Goff
Thanks Robert, but the real early innovators are Marcus, Ian Rodney and Dave Dibb, I started building my 25 pounder 4 or 5 years after the release and have avoided some of the early pitfalls,thanks to them, and have to admit I have used some of their great ideas, I have also put my own interpretations on the kit, this is why we can all benefit by sharing our build experiences on the forum
regards Jeff
Posted: Mon Jan 14, 2019 5:08 pm
by Marcus Kwa
She is a beauty Jeff!!! Looking forward to what you will do with the sighting system!
Oh and don't worry: I will definitely copy a lot of your mods as soon as I have time!!
Marcus
Posted: Mon Jan 14, 2019 10:47 pm
by Robert Reid
Thanks, Jeff.
And thanks for the kudos over on my engine build. Coming from you, that is really, really high praise, indeed!
RPR
Posted: Sat Jan 19, 2019 7:24 pm
by Jeffrey Goff
Hi I have tried out the blank firing of the 25 pounder, works ok, short clip with the sound turned down,
https://www.youtube.com/watch?v=GbCqMiKaRUQ
regards Jeff
Posted: Sun Jan 27, 2019 4:15 pm
by Jeffrey Goff
made a start on the sighting gear, most of the main elements are made, this is what I achieved in 2 days
regards Jeff
Posted: Mon Jan 28, 2019 8:25 pm
by Jeffrey Goff
the kit comes with a solid alloy telescope case that fits to brackets inside the shield, just for fun I thought I would bore this out and see what size the sighting telescope would be, as the photos show it is a tad small, I use the 1/6th figure to show scale, the last picture shows the diameter the new sighting scope
regards Jeff
Posted: Thu Jan 31, 2019 4:41 pm
by Jeffrey Goff
made the sighting scope and storage container, this looks closer to scale, retaining clips to be added to the container, also made and fitted the telescope holder to the sighting gear.
regards Jeff
Posted: Sat Feb 02, 2019 10:08 am
by Marcus Kwa
You have been busy!
The Armortek case is much to small, possibly patterned on the smaller No.29 sighting scope. The No.29 actually needed a spacer tube to fit into the sight clamp. The case for the no.29 scope however did not have the wider section at the lid, the scope did not have any protruding knobs or dials.
The no.41 scope however had 3 knobs/dials and had its case widened to accommodate these. The cap above that widened section also had a larger diameter than the remaining storage tube. Couldn't find my measurements of the actual thing....... :(
I used a rubber bicycle brake-cable bellows to make the eyepiece.
Marcus
Posted: Sat Feb 02, 2019 2:20 pm
by Marcus Kwa
Oeps, I meant No.22 scope, that one is without dials! The No. 29 scope does have a knurled dial/knob on the top, and the No.41 has three.
I work too hard, I definitely have to start building again......
No.22, with storage tube:
No.29, with storage tube:
And no. 41 with storage tube side by side of a No.22 to show the difference in size:
Marcus
Posted: Sat Feb 02, 2019 6:20 pm
by Jeffrey Goff
thanks for all the info Marcus, I am sure we could all go raving mad trying to achieve perfection, I try and make the details look acceptable and in scale rather than having every nut bolt and rivet correct, not sure about the rubber bellows, what diameter are they, the ones I made scale up to 45mm this looks about right.
today I made the quadrant dial and pointer for the elevation,
regards Jeff
Posted: Sat Feb 02, 2019 8:38 pm
by Marcus Kwa
I have to agree with that...... My curse is: I travel a lot and so have too much time to ponder over details :?
When I am finally building, common sense normally kicks in (I do get carried away sometimes(....) :wink:).
That video is fun! Have you tried it with the lights out: is there some kind of flash visible?
Marcus
Posted: Sun Feb 03, 2019 5:02 pm
by Jeffrey Goff
A bit more completed on the sighting gear, made the sliding scale for the ranging cone, remade the quadrant scale for the elevation, the arc now runs true with the pointer, just the bracket for the iron sight to make then clean up the metalwork before painting
regards Jeff
Posted: Mon Feb 04, 2019 7:21 am
by Frank Breitenbach
Hello Jeff
A realy perfect model! Hope to see more impressive Details.
Frank
Posted: Mon Feb 04, 2019 7:15 pm
by Jeffrey Goff
sighting gear almost complete, just a few tweaks and cleaned before painting, parallel motion link is just resting on the brackets, as the sight operating arm needs some work, this is how far I got today, it might be a week or so before any updates, as I have a couple of projects to finish
regards Jeff
Posted: Mon Feb 04, 2019 7:42 pm
by Stephen White
Exquisite Jeff, there's something about these gun projects that lends itself to such fine work. The result is stunning. Sits up there with the best of the 88s. Stephen
