No sound from speaker - new audio option pack
All topics related to Armortek's Sound Option Pack
Oli Dainton
Been Liked: 9 times
Post by Oli Dainton » Sat Apr 04, 2020 7:38 pm
Hello all.
I have the 2018 Panzer III with motion and audio packs.
Drive motion is now working as expected, motors set up as a single stick operation.
I have wired the audio module as per instructions, using the y-leads to feed motors and audio module from channels 1 & 2.
The 3 position switch wire is connected to channel 7 of receiver, I have no other channels connected yet.
I am using a Futaba T7C transmitter and FASST receiver.
I have set the three position switch to channel 7 in the menus.
To test this I connected a servo to channel 7 and sure enough the servo moves from full travel in one direction to centred to full travel in the other direction when I use the 3 position switch.
However, when I turn on the power to tank, I hear the single beep, as expected, but no matter what I do with the 3 position switch, I don't hear any of the sounds from the speaker.
Presumably the audio module just reacts to a full travel signal from that channel to trigger sounds, and the servo proves that is being sent.
I haven't run through the calibration steps as these appear to only be relevant to throttle based sound feedback and the manual states I should be able to play any of the sounds prior to doing any calibration.
Any ideas?
Oli
Has liked: 239 times
Been Liked: 362 times
Re: No sound from speaker - new audio option pack
Post by Adrian Harris » Sat Apr 04, 2020 10:07 pm
I've always gone through the calibration process for every new installation, otherwise the system doesn't know the receiver signal values of the three switch positions.
Oli Dainton
Been Liked: 9 times
Post by Oli Dainton » Sun Apr 05, 2020 8:51 am
Hi Adrian
Unfortunately the calibration process also requires the use of the three position switch. I only hear the beeps during this process as well.
I have seen other threads about sound modules, but since the module is receiving a servo signal correctly for the switch and the speakers do actually work, what else can I do?
Oli
Post by Adrian Harris » Sun Apr 05, 2020 10:36 am
Sounds like you may have another wiped sound card, as per the message here on Friday.
cron
