Chieftain turret turn motor strange behaviour on initial switch on
All topics related to Armortek's Motion Option Pack
michael hilton
Has liked: 748 times
Been Liked: 390 times
Re: Chieftain turret turn motor strange behaviour on initial switch on
Post by michael hilton » Wed Jul 08, 2020 4:02 pm
Hello Adrian, reference your post, just to say I had a problem with my Grant and the new 'red' boxes. As advised by your good self I removed one red power cable into the receiver because the receiver was taking 'two' 5v supplies. This solved my issue. Mick
Been Liked: 838 times
Post by Armortek » Thu Jul 09, 2020 8:42 am
Mark Russell wrote:
Tue Jul 07, 2020 6:53 pm
Hi I have made a significant development hopefully in respect to this issue. If I disconnect the turret plug then this issue does not happen 😀😀😀. I can turn on and the turret motor remains stable. Reconnect the turret plug and the fault occurs again. So next step leave the turret plugged in and disconnect the power supply to the 5 volt voltage regulator used to supply the recoil unit. I can turn on the main power switch and the turret motor doesn’t turn. Reconnect the recoil power supply and the turret motor turns on main switch on.
So it has to be something to do with either the 5 volt power supply and/or the recoil unit. Any thoughts guys...
If you are still having issues then suggest you drop us an email and we can work through this.
We have used various Spektrum transmitters and receivers over the last few months for custom builds and have not seen the issue you have.
Kian
