The V2 project
- Has liked: 19 times
- Been Liked: 133 times
Re: The V2 project
Superb build Phil, love your enthusiasm and skill and the ability to think outside the box in problem solving,
watching with interest, one of my projects to do is a V1, I already have a working pulse engine
Regards Jeff
Regards Jeff
- Has liked: 1165 times
- Been Liked: 3024 times
Re: The V2 project
Well it keeps me occupied! I'm very familiar with the pulse jet, I still have the operators manual that that I wrote for the MOD many moons ago . My god they are loud! I believe they were restricted/banned in the UK for modellers but a slower pulse example is used in the horticultural industry for misting fruit trees.
Re: The V2 project
A quick update on the Protze conversion, won't get much done today in the workshop as it's the wife's Birthday.
- Stephen White
- Has liked: 434 times
- Been Liked: 1109 times
Re: The V2 project
Phil, enjoying watching your progress, shows what can be done with skill and imagination. The springs might be easier to make from scratch. It’s a lot easier than I’d anticipated, if you’ve got a lathe. Some ideas here:
http://www.armortek.co.uk/Forum3b/viewt ... b2085c99a6
Re: The V2 project
Thank you Stephen, malleable wire used to make modelling springs be it compression or extension is no problem as you have demonstrated, you try a fully functioning 30mm x 3mm x 76mm made from high tensile steel wire, the energy in that thing will take your nails off, I made one using the lathe, it's very satisfying but nothing is as good as a manufactured spring, getting the ends bent and ground is tricky to.
I bought a large to medium spring selection from ebay for about a tenner, there must be 150/200 in the package!
Re: The V2 project
A very short update on the Protze as i am busy landscaping at home on the range, the weather here in the West Country has been magnificent this week.
- Found some of the correct dash decals
- krupp-protze-instruments-placards-and-resin-details-.jpg (12.53 KiB) Viewed 3488 times
- The two switches on the dash are for, power on, then the second is to isolate the motor, this does 2 things, allows you to statically run the engine sounds etc without fear of the model running off by itself but also allows the older Armortek speed controller to kick in before being switched on to power the motor, basically allowing the esc twitch to stabilise before the motor in connected (if that makes sense ?)
- The condensed control equipment birds nest, this uses an older but brand new early Armortek 10amp esc, this being plenty large enough for the 3amp motor but nice and compact as space is at a premium, the tbs mini is taken from the sound module and is now naked.
"Two 5 amh gell batteries are nice and light (you could go bigger capacity with the same physical size but I'm keeping the weight down. I now need to tidy this lot and store it all it a nice wooden period crate.
Re: The V2 project
Although it doesn't look like much progress that dam opening and folding windscreen has been many hours of work!
Last edited by Phil Woollard on Tue Apr 02, 2019 8:21 pm, edited 3 times in total.
- Has liked: 371 times
Re: The V2 project
Five stars for the spring! Very uniform and nice looking.
Re: The V2 project
The wood work, God I'm not so keen on wood work, didn't really like it at school either. Jesus (as a carpenter) must have had the patience of a Saint!
Re: The V2 project
More wood work this afternoon making the rear bench seats. Also just booked myself in for replacement eye lens surgery, I'm fed up with glasses, I want my teenage eyes back, that way my eye for detail will be that much sharper, worth every penny of 7k!
Re: The V2 project
Finished the crew bench seating and started the top coat.
Re: The V2 project
This may may make some glaze over, as the project is going so well I am now upgrading the cast ali parts to machined ali parts, like the steering king pin posts and steering carriers whilst adding brass bushes to the same, all done with out the use of machines, just hand tools and good old fitting. All this may seem a little over the top but it's the difference between a good runner and a very good runner.
I have also removed the Dunlop logo from the tyres.
Last edited by Phil Woollard on Wed Apr 10, 2019 4:45 pm, edited 2 times in total.
- Been Liked: 40 times
Re: The V2 project
Hi Phil
Looking very nice indeed, and the ackerman looks good now, but what about that shocking scrub radius…?
Liam
Liam
Re: The V2 project
Hi Liam, that's what the TX is for init? Armortek tyres are so hard it won't really matter
Re: The V2 project
For those that like the weathering process, well my brand of weathering anyway.
