New King Tiger , Tiger I and T34 components.
John Grima
Been Liked: 27 times
Post by John Grima » Tue Aug 07, 2018 4:02 am
Hello everyone, It's been awhile since I posted on this forum, however that doesn't mean I have been neglecting any builds or tooling up new parts... quite the contrary. Since I wrapped the Sherman Firefly and a vintage early armortek tiger 1, I have been focusing my time on 3 armortek builds. A King tiger, a T34, and another early tiger I 131. While working on these three I have spent the last several months tooling up new parts in cast metal and 3D print.
Starting with Tiger I, I tooled up a new set of main fuel tank covers / air intake ducts. These are 3D printed and have replaced the sheet metal ones that have been on the ECA Catalog for a number of years, and the metal ones are now OOP. These new parts are found on the following link, http://eastcoastarmory.com/tiger.htm
These units are comprised of a single print and no construction needs to be done to them, they are ready to go out of the box. They are also right and Left hand specific like the real units and my older pattern metal ones.
Once painted they give the frill area a nice pop
As for the King tiger The First new detail I have is a replacement for an older set that I've produced for several years in resin. The detail is of the Hub Cap fastener / retention plates. The older sets molds are now worn out and rather then make new molds I went ahead and replaced them with these new sets in 3D print. http://eastcoastarmory.com/kingtiger.htm
The sets contain several units for not just to complete one tank, but also spares to replace any if one were to get loose / fall off
As for New parts I tooled up the bump stops. These are comprised of Cast metal, Cast resin, and also rubber.
As for the T34, the new parts are found on the new T34 parts catalog page, http://eastcoastarmory.com/t34.htm
Starting with the model's bump stops, these are Cast metal components that use real rubber for the bump stop.
The next newly tooled up metal detail set is the T34 swing arm aligner rail set.
The T34 family track pin aligner set was another cast metal component I developed,
Some other Parts I developed for the T34 are in the 3d Print media, Starting with first Front Idler hub cap replacement set,
I also designed replacement hubs for the main road wheels... Just like with most vehicles there are several examples of hubs that were created / used. I was able to make these three variants,
T34 road wheels hub set style 1,
T34 road wheels hub set style 2,
T34 road wheels hub set style 3,
I've also designed a drive sprocket detail face upgrade for the Armortek T34 Sprocket. This set gives the stock sprocket a Late type pattern compared to the early pattern which is present on the stock armortek kit and would not be a very common sight on the T34/85. Currently I'm wrapping up this conversion on the example I'm working on, however the sets are posted on the site. If you notice these are printed in a black material... due to the location of these parts they will get more wear and tear compared to the hubs. Because of this the black material is better for when the paint scratches / chips revealing the base material, which black looks better then white.
I got lots of more stuff in development now for all three vehicles and as they progress more new sets will be released... more to come.
Brian Ostlind
Has liked: 454 times
Been Liked: 614 times
Re: New King Tiger , Tiger I and T34 components.
Post by Brian Ostlind » Tue Aug 07, 2018 4:17 pm
Nice! I can’t wait to order some parts for my Late Tiger I.
epic
Been Liked: 71 times
Post by Robert E Morey » Fri Aug 10, 2018 1:48 am
Great stuff John, really like the idler and hub caps (T34).
John Grima
Post by John Grima » Sun Aug 04, 2019 6:39 am
While working on some builds I've developed more detail upgrade parts. More are in development now, and will be posted once ready.
New Tiger I parts, all parts are found here http://eastcoastarmory.com/tiger.htm
Tiger I rear storage bin. This unit is fully detailed and is functional. This includes both the lids and the latches
3D printed Armortek Tiger I escape hatch detail insert set. This set is designed to add the interior detailing to the stock CNC pattern armortek tiger I escape hatch.
3D printed early Tiger I engine hatch air intake set,
3D printed Tiger I engine hinge access plate detail set.
3D printed Tiger I engine hatch locks set. There are a few options available as these locks changed during the tiger's production run. Some sets are designed for the initial / early variant that had the snorkel feature. Other sets are for the mid / late pattern tigers. Other options include sets that are for tanks with interior details while others are exterior detailing only. This way you are not purchasing parts that you don't need
3D printed Armortek Tiger I pistol port cone fastener set.
3D printed Tiger I Lower Hull fuel tanks set. This set also has two options, One is just the face detailing only and has an open back section. The other is a complete set where the rear sections are included. Both sets include the strap detailing and the fuel line connector valves.
For the M3 Lee,
3D printed M3 Lee rear tail lights set. These are printed hollow to allow the addition of a LED or a bulb. The face detailing is printed in a translucent HD material for crisp detailing and to allow the light to go through. http://eastcoastarmory.com/m3_lee.htm
The sets have both the standard red tail light, and the blackout right hand pattern
Like I mentioned above I got more new sets in development. Some are new items, others are replacements for older legacy items, as for what they are... all I can say is stay tuned!
Tim Carr
Has liked: 349 times
Been Liked: 14 times
Post by Tim Carr » Sun Aug 04, 2019 3:27 pm
Very Nice. Looking forward to seeing more. THANKS for the utube videos.
Later Tim
Tampa Bay, Fla area USA.
Scott Boyd
Has liked: 35 times
Been Liked: 13 times
Post by Scott Boyd » Sun Aug 04, 2019 11:10 pm
Thanks John, love the parts I already have for my upcoming KT build. Love the bump stops your created! Every KT build should upgrade to these!
Looking forward, hopefully, to more KT upgrade parts!
John Grima
Post by John Grima » Wed Oct 30, 2019 4:35 am
After a few months of gathering research materials, I'm now able to announce the newest full ECA kit... WWII German fuel drum trailer
Kit is designed to be used with the Dragon metal german fuel cans, and / or the cast resin drum copies on aliexpress.
Just like with my jeep trailer kits, this model is designed to have the most amount of detail present; however have the least amount of parts that need to be fitted. So far the count of parts are about 7 (wheels / tires not included)
The kit is fully 3D printed, with the same materials that are used on the parts above and the only parts that are cast are the tires, which are made from rubber as what was seen on the line of jeep trailers / jeep tires sets. the rims are a separate printing and are printed in white nylon
I have a set in print now and once in hand I'll be able to get one finished up and hitched up to my tiger
John Grima
Post by John Grima » Tue Feb 11, 2020 10:40 pm
Update, A pre production fuel trailer arrived last month and was built / fitted to a tiger (although this may or may not be 100% accurate for this vehicle). The test unit assembled quickly but I saw some areas for improvement with the production models.
I made these tweaks and the production sample came in the other day. The set is now available on the ECA catalog,
http://eastcoastarmory.com/soft_skin.htm
I have also completed the CAD work for the dual drum trailer aswell and this too will be added to the catalog shortly.
Other new parts to mention are the german AFV clamps. These retired the old resin set that was offered in the past. These units are fully functional once assembled
Also for the King Tiger / Jagdtiger owners I'm in the process of finishing up the complete fan / radiator interior cluster. More will be posted about this set once I have more details / features completed, but these will be released soon, a quick sneak peak however is in order,
I'm also working on other new KT parts now and will be posting more information as that build carries on, more to come!
Scott Boyd
Has liked: 35 times
Post by Scott Boyd » Wed Feb 12, 2020 9:20 pm
Love it John! Can’t wait and keep them coming!
