Painting the Elefant
Been Liked: 379 times
Post by Armortek » Mon Jul 08, 2019 11:14 pm
To officially launch our in-house painting service, over the next few weeks we will be painting the Elefant Heavy Tank Destroyer.
We will document progress along with notes on the techniques used. You will see that in this case we are starting with the already-assembled model.
Step 1 has been etch priming. In this case finished off a can of Halfords Etch Primer before moving on to the prefered U-Pol Power Can Etch Primer
(https://www.u-pol.com/uk/en-uk/product/ ... SO_qOj0lPY)
Re: Painting the Elefant
Post by Armortek » Mon Jul 08, 2019 11:23 pm
Next step has been to add some texture to the metal.
This has been done with a fine car filler. To get the right consistency, the filler is left to dry out a bit to give it a "tacky" texture. It is then applied with a brush by dabbing it on.
The filler can also be used to fill in any holes.
It will need to be left to set for a day before the next step - light sanding to flatten the filler slightly.
