Transmitter Systems
Provides official comments and advice from the Armortek design team
Has liked: 239 times
Been Liked: 365 times
Re: Transmitter Systems
Post by Adrian Harris » Mon Feb 24, 2020 10:44 am
Which electronics do you have ?
The Motion Control Module, which was usually supplied with the Quad, has Switch 3, which can be adjusted to allow for 20ms or 7mS compatibility.
If it's not working at the moment, try changing the position of switch 3 and see if that helps.
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Mon Feb 24, 2020 11:24 am
Adrian,
I happened to obtain this 2nd hand Morris Quad C8 model from Germany, the electronics in the vehicle are :
Armortek Motion Control Module & Armortek Audio Module.
The original owner claimed that he was using brixl controller. What transmitter I can use to match that?
Gilbert
Post by Adrian Harris » Mon Feb 24, 2020 12:08 pm
Have you tried changing switch 3 to see if that helps with your Futaba system ?
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Mon Feb 24, 2020 1:15 pm
Will try to do that in the morning.
Gilbert
Has liked: 250 times
Been Liked: 84 times
Post by Christoffer Ahlfors » Mon Feb 24, 2020 7:24 pm
Brixl uses standard 20ms
Peter Silcock
Has liked: 38 times
Been Liked: 11 times
Post by Peter Silcock » Tue Feb 25, 2020 8:57 am
[quote="Gilbert Pun" post_id=74321 time=1582550102 user_id=236613]
Gilbert
[/quote]
Gilbert are you satisfied that the 18SZ is binding correctly with your receiver? The 18SZ I had only appeared to work with S & T - FHSS, FASST and FASSTest receivers. Is your receiver one of these?
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Thu Feb 27, 2020 7:55 am
Adrian,
Thank you very much, it works after changing to up side with the Switch 3.
The Data frame rate is now working with my 18SZ Faastest system.
Except that I still unable to control the motor :
there is no neutral nor forward for the motor control, whenever I switch on the motor runs nonstop reverse and no reaction to the throttle control!
Gilbert
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Tue Mar 10, 2020 9:48 am
Unfortunately after all the tests this whole week, the final result proves that the Fasstest system of Futaba 18sz system does not syn with the old system Armortek electronic systems. Finally I managed to use a Spektrum DX6 and it syn with the system and Quad C8 vehicle is now running comfortably.
My need is actually for 9+ channels to operate these vehicles. Would any body on the Forum have experience using Spektrum DX9 or ix10 or ix20 for these older models?
Gilbert
Post by Adrian Harris » Tue Mar 10, 2020 10:01 am
I have used a DX9 and AR9020 receiver with Armortek kits and they work well together.
I believe that any Spektrum system which uses DSMX should be OK.
Peter Silcock
Has liked: 38 times
Post by Peter Silcock » Tue Mar 10, 2020 12:13 pm
My 18sz worked perfectly with all the different Armortek modules. The previous owner did have all the latest software upgrades done though, which may have made a difference.
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Thu Mar 12, 2020 1:24 am
Does anyone out there know how to upgrade the software to allow 18SZ to suit the old and new Armortek modules?
Or, anyone can offer the service to help ?
I currently have a couple of 18SZ for use on other air and sea models and hate to see the transmitters idling there when running land models.
Gilbert
Post by Adrian Harris » Thu Mar 12, 2020 9:29 am
This video shows how to do the upgrade.
https://www.youtube.com/watch?v=9N-aGVPQEl0
Adrian
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Sun Mar 15, 2020 1:45 am
Do you mean to upgrade the 18sz only ?
Gilbert Pun
Has liked: 4 times
Post by Gilbert Pun » Thu Apr 02, 2020 9:45 am
HI everyone,
After the upgrade etc on Futaba 18sz still unable to syn with the Amortek electronic modules !!
Last week, after looking through all the Spektrum specifications whilst looking for the latest models, since ix20 is out of stock till May, I finally ordered a Spektrum ix12 with a 9 ch receiver, tried to hook everything up this afternoon, and now all are working fine.
I have to thank Kian for the advice of changing to Spektrum system.
Gilbert
Post by Adrian Harris » Thu Apr 02, 2020 11:26 am
Glad to hear you got it working :-)
cron
