Painting the sponsons
Has liked: 59 times
Been Liked: 73 times
Post by Adrian Harris » Sun Jul 29, 2018 10:27 am
What have people done when painting the sponsons ?
Did you prime the drums and guns separately, or construct it all and paint it once complete ?
I suppose I'm only really worried about the top coat gumming up the guns and drums.
R.I.P Margaret I.L.Y
Has liked: 59 times
Re: Painting the sponsons
Post by Adrian Harris » Sun Jul 29, 2018 10:58 am
On a related note.
If I attached the female sponson tops using the M4 screws at the back, it sits about 1mm too high, with a gap at the back and the front armour plate holes don't line up. If I get the fronts to line up, the back is also flush with the mounting frame.
Chris, do you remember if you had to open up the 4mm mounting holes on Liesel ?
Chris Hall
Has liked: 43 times
Been Liked: 39 times
Post by Chris Hall » Sun Jul 29, 2018 6:18 pm
Adrian -
I painted the guns, drums, and push rods for the 'wiggly gun pack' separately from the main sponson plates (which I also painted separately after adding things like the periscopes), and then assembled it. Then it just needed a blow-over for the rivet heads. There are so many moving parts that it would doubtless gum up if you painted it all at the end. I also found there were numerous fiddly adjustments to make before everything moved freely - even some of the blank rivets along the top edge needed cutting down or they would jam the drums !
I can't recall any gaps on Liesel, and I certainly didn't need to drill out any mounting holes. It probably took a few goes (and perhaps a bit of pressure) to get everything aligned ...... perhaps I was just lucky.
All the best,
Mark IV's #50 (Liesel) and #30 (Flaming Fire II)
Morris Quad #34, limber and 25-pdr
M3 Lee on the way !
