A 47 years old love
- Been Liked: 8 times
Re: A 47 years old love
Very tidy!
What printer and print setting do you use for small parts?
cheers
Fabrice
cheers
Fabrice
- Has liked: 22 times
- Been Liked: 358 times
Hello Stephen and Fabrice
Many thanks for your kind words.
To your questions Fabrice:
The 3d printer is a Zortrax M200. I have following main adjustment options: Layer thickness from 0,09mm to 0,19mm and to print only the surface with a support inside between 40% and 100% (a complete 100 % full print). The minimum part thickness is 0,8mm. The main problem is to place the part that I have the best result. It is a question of experience - I will say, many fails.
I hope I had find the right words.
All the best
Frank
All the best
Frank
Hi Fabrice
The diameter is 0,4mm nozzle/ 1,75mm for the filament. There is no option.
I use normaly the ABS Filament. For me it is a good balance between Price and shrinkage.
Frank
Frank
Hello at all
The hull is now complete. The last part was the head lamp. I saw it at the Bovington Centurion. I have only one photo. So I hope it is ok.
All the best
Frank
All the best
Frank
Hello Fabrice
In fact it is very easy.
The parts I bought more than 20 years. The 8V lamp gets 12V. The lamp mirror with a little modification and the lens gets a 3D cover.
Frank
Frank
- Has liked: 374 times
- Been Liked: 133 times
Hi Christoffer
No, no. The 8V lamp used with a 3s lipo (exact 11,1 V). So the light is a little better.
Frank
Frank
It will burn out in no time.
10% overvoltage cuts the life in half.
Hello at all
After a long time now I can go back zu my hobby.
Actually I build the turret bins.
Frank
Frank
- Been Liked: 693 times
Very nice, a lot of work goes into the small details, Excellent, regards simon manning.
Hello Simon, thank you.
That is right, but more details makes our models more interest and it makes fun.
Frank
Frank
- Has liked: 13 times
- Been Liked: 229 times
Frank,
Excellent looking bins and hardware. Looks like you milled the strap buckles? What size is the cutter bit that you used? Nice work!
B
B
