A 47 years old love
Frank Breitenbach
Has liked: 22 times
Been Liked: 351 times
Re: A 47 years old love
Post by Frank Breitenbach » Sun Jan 31, 2016 10:43 am
Hello next one
The absorber lever housing.
Frank
Has liked: 434 times
Been Liked: 1109 times
Post by Stephen White » Sun Jan 31, 2016 11:28 am
That's impressive work Frank. Makes me wonder why I'd doing it all by hand! It seems the latest 3D printing materials technology has advanced to the point where it's robust enough for working parts although I guess it isn't yet strong enough to be functional?
I can think of dozens of Cent parts which would benefit from this technique.
Thanks for inspiring us.
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Sun Jan 31, 2016 12:46 pm
Hello Stephen
The main problem is to create the stl file from the part. The printing material (filament) is ABS. The 3d process printing temperature is 230 - 250 c°. I am working with 0,09mm layer.
To your question if the material is strong enough or not: You can get different ABS. But in this case I beleve there are not so much strength. I think it works. If a part is broken no problem I can print it again. :roll:
And yes: It is a very nice technology and I like to print parts. Printing,assembling and ready.
For example: The turret grenade mounts (EH0429) are perfect parts to detail it.
Frank
davidwilkins
Been Liked: 182 times
Post by davidwilkins » Sun Jan 31, 2016 1:56 pm
Impressive work Frank, it is nice to see another centurion build taking shape.
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Sun Feb 21, 2016 6:34 pm
Hello
A little bit progress.
Frank
Post by Stephen White » Sun Feb 21, 2016 7:19 pm
Looking very good indeed Frank. Your 3D printer is making easy work of these modifications. Do let me know if you need any reference pictures. Regards. Stephen
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Fri Mar 04, 2016 7:59 pm
Hello at all
Stephen I need your help. But later when I will build the external fuel tank.
Well some picures
As every time following Stephens report.
Regards Frank
Fabrice Le Roux
Been Liked: 8 times
Post by Fabrice Le Roux » Fri Mar 04, 2016 11:41 pm
Hi Frank,
Bravo, looking good.
That mighty dozer blade is looking, well, unattached? :(
How are you planning to make it work? Miniature Hydraulics, Pneumatics or Linear Servos?
Lovely work :) .
cheers, Fabrice
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Sat Mar 19, 2016 2:26 pm
Hello at all
@ Fabirce: Yes I am planing with a miniature hydraulic.
Well my engines
Frank
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Mon Apr 18, 2016 7:34 pm
Hello
My electric external fuel tank. I hope it is enough power for 30 minutes. :roll:
Many thanks Stephen.
And the rope thimble for a 5 mm rope.
Frank
Günter Gäbelein
Has liked: 13 times
Been Liked: 74 times
Post by Günter Gäbelein » Tue Apr 19, 2016 6:54 pm
Hi Frank,
the tank looks fine! I think the 24V lippo is enough for 30 minutes driving, but the 12V lippo for all the electronic functions, sound and animations could bring limitations :lol:
Günter
sean kerambrun
Has liked: 17 times
Been Liked: 5 times
Post by sean kerambrun » Fri Apr 22, 2016 3:57 am
Hi Frank,
Nice work.
One question What motors did you use? What are the specs?
Sean
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Sat Apr 23, 2016 10:48 am
Hello Sean
The motor is from Parvalux:
PM63-100 GB12, 24V, 365W ,PB25:1, S3 rating, 184rpm, 17,3 Nm.
I know very heavy but a little bit more than to less power.
Frank
Günter Gäbelein
Has liked: 13 times
Post by Günter Gäbelein » Sat Apr 23, 2016 11:21 am
Hi Frank,
but less power would be more scale for the Centurion :wink:
Günter
Frank Breitenbach
Has liked: 22 times
Post by Frank Breitenbach » Sat Apr 23, 2016 11:26 am
Hi Günter
That is not fine. :roll:
Frank
