A 47 years old love
Fabrice Le Roux
Been Liked: 1 time
Re: A 47 years old love
Post by Fabrice Le Roux » Fri Mar 27, 2020 10:26 am
Very tidy!
What printer and print setting do you use for small parts?
cheers
Fabrice
Frank Breitenbach
Has liked: 14 times
Been Liked: 182 times
Post by Frank Breitenbach » Fri Mar 27, 2020 5:29 pm
Hello Stephen and Fabrice
Many thanks for your kind words.
To your questions Fabrice:
The 3d printer is a Zortrax M200. I have following main adjustment options: Layer thickness from 0,09mm to 0,19mm and to print only the surface with a support inside between 40% and 100% (a complete 100 % full print). The minimum part thickness is 0,8mm. The main problem is to place the part that I have the best result. It is a question of experience - I will say, many fails.
I hope I had find the right words.
All the best
Frank
Fabrice Le Roux
Been Liked: 1 time
Post by Fabrice Le Roux » Fri Mar 27, 2020 6:32 pm
Frank,
what nozzle size and filament do you find best?
cheers Fabrice
Frank Breitenbach
Has liked: 14 times
Post by Frank Breitenbach » Sun Mar 29, 2020 1:39 pm
Hi Fabrice
The diameter is 0,4mm nozzle/ 1,75mm for the filament. There is no option.
I use normaly the ABS Filament. For me it is a good balance between Price and shrinkage.
Frank
Frank Breitenbach
Has liked: 14 times
Post by Frank Breitenbach » Wed Apr 01, 2020 12:42 pm
Hello at all
The hull is now complete. The last part was the head lamp. I saw it at the Bovington Centurion. I have only one photo. So I hope it is ok.
All the best
Frank
Fabrice Le Roux
Been Liked: 1 time
Post by Fabrice Le Roux » Wed Apr 01, 2020 1:01 pm
Frank,
Outstanding! Just the right colour light.
Fabrice
Frank Breitenbach
Has liked: 14 times
Post by Frank Breitenbach » Thu Apr 02, 2020 9:58 am
Hello Fabrice
In fact it is very easy.
The parts I bought more than 20 years. The 8V lamp gets 12V. The lamp mirror with a little modification and the lens gets a 3D cover.
Frank
Has liked: 248 times
Been Liked: 84 times
Post by Christoffer Ahlfors » Thu Apr 02, 2020 8:41 pm
You do mean the opposite, don't you? :?
Frank Breitenbach
Has liked: 14 times
Post by Frank Breitenbach » Sat Apr 04, 2020 3:36 pm
Hi Christoffer
No, no. The 8V lamp used with a 3s lipo (exact 11,1 V). So the light is a little better.
Frank
Post by Christoffer Ahlfors » Mon May 04, 2020 10:29 pm
It will burn out in no time. :shock: 10% overvoltage cuts the life in half. :!:
cron
