Panther A barrel elevation
yves mouton
Been Liked: 43 times
Post by yves mouton » Fri Aug 09, 2019 10:21 am
Hello,
The elevation of the barrel down works ok,
but the barrel elevation up does not work without a little help.
So my question is: do i have to make a counter weight the help the motor
put the barrel up?
Best regards Yves
Has liked: 239 times
Been Liked: 362 times
Re: Panther A barrel elevation
Post by Adrian Harris » Fri Aug 09, 2019 5:08 pm
I've seen this in the past when the current limiting resistor in the elevation motor supply is too sensitive.
Counter-weighting the barrel should reduce the load on the motor and allow it to operate correctly.
yves mouton
Post by yves mouton » Sat Aug 10, 2019 7:18 pm
Thanks Adrian
Best regards Yves
