Mg flash/2019 module
- Has liked: 3 times
- Been liked: 437 times
I have the latest 2019 modules and would like to connect a Steve Winston mg. Can someone advise me as to which pins do I connect the red and black mg cables to.
- Been liked: 227 times
Re: Mg flash/2019 module
Hello Steve,
I tought on the in or output nr 4 on the audio module.
Best regards Yves
Best regards Yves
Hello,
I test today my MG 34 light the led stays on on the audio output 1 or 2 ( so the light works )
if i put the wire in output 4 or 5 nothing happens?? In audio 3 works the recoil module.
Newest red modules
Help Please
Best regards Yves
Newest red modules
Help Please
Best regards Yves
Thanks Yves
I have got mine working.
I used audio output no4, black wire to middle pin and red wire to lower pin.
Hi Steve,
I did try that but nothing happens in output nr 4??
Best regards Yves
Best regards Yves
- Has liked: 483 times
- Been liked: 556 times
It depends on the programming on the Benedini TBS sound board. I've noticed on at least one sound card that the MG sound used is a long burst of MG fire, rather than a single shot repeated. This means the MG LED only flashes once at the beginning of the burst, not once with each shot.
It can be changed by reprogramming the TBS board, which I have done for some customers, but opening the Audio Module invalidates the warranty.
Thanks Adrian,
I will check the different sounds and see if one of them work.
Best regards Yves
Best regards Yves
Hello,
I test today again the MG light in out put nr 4,5,6 the sounds work ( all different MG ) but no light flash?
if i put the led in output nr 1 or 2 the light stays on, so that can be used for the notek lights.
Normaly if the sound works of the MG the light have also work?
Best regards Yves
Best regards Yves
Hello,
I test yesterday the stug MG light in my panther and the led works ok.
I dont know whats wrong that the light dont flash in the audio output nr 4 (red module of the stug )
Is it because my panther has the older modules ( alu look )
Best regards Yves
Best regards Yves
- Tim Page
- Has liked: 15 times
- Been liked: 139 times
It sounds to me like the new audio module has not been configured properly.
I have just setup a TBS mini to work with my P3 and had some problems getting the MG to flash correctly.
There are a couple of setting that need to be configured or it just wont work.
Unfortunately, as Adrian says, opening the box invalidates your warranty so i would contact Armortek directly.
2008 Armortek Panther ausf.G #0035
2009 Armortek BefehlsPanzer 111 ausf.J #0011
Thanks for the info Tim,
I don't have the knowlegde the program the module myself,
so maybe i can ask someone to help me on a Armortek openday?
Sending now the module the UK and back to Belgium cost to mutch for me ( don't like the goverment take money out of my wallet )
Or i can send the module to Thomas B
Best regards Yves
Best regards Yves
- Been liked: 7 times
if you go to Thomas Benedini's website,
you can download the program for free,
you must first send an email to Thomas who will send you User and password,
the program is quite intuitive,
it allows you to program the flash of the Mg, that of the Gun and the recoil through a servo,
and also the various lights,
but be careful that it has the outputs at the voltage of the receiver (bec from the esc 5 o 6 Volt)
Marco
Marco
- Tim Page
You also need to purchase the USB programming lead and there is also the matter of voiding your Armortek warranty.
