Page 1 of 3
Adam's Panzer III build
Posted: Tue Dec 18, 2018 7:11 pm
by Adam Osga
And so it begins!
Shipping was ridiculously fast as I received my kit yesterday and had ordered it middle of last week. Hopefully I can get it home tomorrow (it's at my office right now) and start sorting this weekend. I'm going to try to take photos and post updates regularly for feedback.
Re: Adam's Panzer III build
Posted: Tue Dec 18, 2018 8:04 pm
by Brian Ostlind
Very cool Adam get ready for the peanuts have a can nearby when u open it up!
Posted: Tue Dec 18, 2018 8:06 pm
by Vince Cutajar
I love new builds. I'll be pulling up my chair and popcorn.
Posted: Tue Dec 18, 2018 11:25 pm
by Adam Osga
Hmmm, it’s been a while since I used photobucket. Is there a way to post without the photobucket information showing on my photos?
Edit: I ended up using Imgur instead to get rid of the watermark
Posted: Wed Dec 19, 2018 1:05 am
by Brian Ostlind
I use imgur. I think most folks here had a bad experience with pb
Posted: Wed Dec 19, 2018 5:47 am
by Pete Nash
Hi Adam
I hope you have an enjoyable time building your Panzer III.
Despite MY mistakes and 'problems' I know I have.
If you still believe in Santa Claus have a merry Christmas, If you don't......Bah humbug! :D :) 8) :lol: :P
Posted: Thu Dec 20, 2018 6:39 pm
by Adam Osga
So I'm going to start priming this weekend going with a recommended cleaner/conditioner and epoxy primer recommended by a local auto supply place near were I live. I plan on a very light and thin coating or a couple of super thin coatings using my spray gun. We'll see how things turn out.
Posted: Thu Dec 20, 2018 7:48 pm
by Adam Osga
A question about Loctite products. I notice people use various different types and wondered why. I've seen some using the red on fasteners, which required major effort to separate, rather than the blue and I was curious about the reasoning. I was considering using blue for fasteners and the 620 for sleeves and such. What are some thoughts?
Posted: Thu Dec 20, 2018 10:22 pm
by Brian Ostlind
I think it comes down to personal build technique. There is no right or wrong technique. Obviously you want to put the red stuff where it’s indicated on the manual to do so. Otherwise, yes the blue stuff is more appropriate for the fasteners especially if you have to back track! My guess is the more experienced builders won’t need to undo anything and go with the red stuff on more fasteners.
Posted: Fri Dec 21, 2018 10:12 am
by Stephen White
Adam
The Knowledge Base on this Forum is a good place to look for answers. It should cover all the basics and some more advanced custom building topics. If it doesn't adequately cover a subject you're interested in, please make a suggestion. The subject of securing fasteners is covered here:
http://www.armortek.co.uk/Forum3b/viewt ... 96b9af46ce
There's also a topic on Priming and Painting, here:
Enjoy you're Pz III - it's one of Armortek's finest.
Posted: Fri Dec 21, 2018 12:11 pm
by Andy Walker
Blue should be fine for the majority of fasteners. I have been building and flying radio control helicopters for many years now, and all the fittings are blue threadlocked. As you can imagine there is a lot of vibration and g forces involved when flying and I have never had a fitting come loose ever. And when the inevitable crash occurs they are easy to remove.
Posted: Sat Dec 22, 2018 4:07 am
by Adam Osga
Decided to start seeing how things go together with some rough fitting tonight. Tomorrow I organize bags a bit better and get an organizer for all the nuts and bolts. I may start cleaning the aluminum and preparing for a primer coat.
Posted: Sun Dec 23, 2018 4:13 pm
by Adam Osga
So this is an effect of the aluminum conditioner prior to painting. Apparently it’s called a chrome conversion coating. Interesting.
Some priming has been done
Posted: Tue Dec 25, 2018 3:21 pm
by Adam Osga
So I've made a bit of progress. Luckily we've had two amazing days in a row so I've been able to work outside cleaning, prepping and painting. Plus I have most of today to continue to tinker.
Merry Christmas!
Working on Road Wheel Assemblies
Posted: Thu Dec 27, 2018 2:29 am
by Adam Osga
Hey everyone,
I'm currently working on the road wheel assemblies and the nut that goes through the side hull and suspension bar then into the suspension shaft is supposed to be an M6x25 CSK (per the manual). I looked in the parts list and I was supplied 12 M6x30s so I have to assume that is what they are for. But when I try to thread it all the way it bottoms out in the suspension shaft so the side hull does not bolt very tightly to the suspension bar. Are these supposed to be modified/shortened or something? I have to assume someone else has run into this. I suppose I could go to Fastenal and order some M6x25s if absolutely necessary.
Thanks,
Adam
Edit, here is the assembly page:
