Page 4 of 9
Re: Martin's Jagdpanther
Posted: Tue Sep 26, 2017 6:17 pm
by Martin Hofmann
Hi Per,
thank you for the information - yes it is to late - maybe. Do you have some photos of this area? and where do you get your informations, do you have drawings?
Posted: Wed Sep 27, 2017 7:36 pm
by William Gardeniers
Hello Martin
on this side are some photo's http://www.primeportal.net/tanks/john_g ... gdpanther/
Posted: Thu Sep 28, 2017 7:38 am
by Per Sonnervik
Hi Martin,
I don´t have original drawing of Jagdpanther parts but photos below reveal details; here´s one from the Jagdpanther in Kubinka and as you can see the metal strip is spot welded on and at the arrow (marked 1) you see the outer edge is chamfered to meet the rubber seal:
close up of spot welds;
On the Tiger II´s drivers and MG operator´s hatch the same type of strip is used to hold the rubber seal, this is from an original drawing;
/Per
Posted: Wed Oct 04, 2017 4:43 pm
by Martin Hofmann
Hi Kent, William and Per,
thank you very much for the interesting informations, details and photos.
Here are the next photos of the idler wheels with some details.
Posted: Wed Oct 11, 2017 3:59 pm
by Martin Hofmann
In the mean time i did some progress on the floor plate - with some holes for the bottom covers. It looks like a cheese from switzerland :lol:
and i start the mounting of the hull......
Posted: Tue Oct 24, 2017 5:53 pm
by Martin Hofmann
Here some more photos from the hull and the idler with new threads and the casting surface......
Slowly she looks like a JP....
Posted: Wed Nov 01, 2017 4:48 pm
by Martin Hofmann
i have built some more details on the drive housing.
Posted: Wed Nov 01, 2017 8:41 pm
by David Battson
Hi Martin, Great work on the jagdpanther, lots of nice details.
Just one observation, have you checked that the sprockets won't clash with the drain plugs you've added - it looks very close.
Regards David
Posted: Fri Nov 03, 2017 4:29 pm
by Martin Hofmann
Hi David,
thank you for the observation, i had checked the dimensions of the sprocket to the drain plugs - before placing them! :D :D
Here comes the housing with casting numbers and some radii at the adding parts.
Posted: Tue Nov 07, 2017 5:37 pm
by Martin Hofmann
After the radii i scratched the surface for Mr. Surfacer to create a casting structure
Posted: Wed Nov 08, 2017 9:15 am
by Rolf Mönke
sehr schön!!
Posted: Wed Nov 08, 2017 10:52 am
by Sam Hough
Fantastic work!
Posted: Thu Nov 09, 2017 6:41 am
by Robert E Morey
Wow those drive housings look awesome! Great work Martin! I'm loving all the details!
This JP will be superb with those steel tracks.
Posted: Fri Nov 10, 2017 3:40 pm
by Martin Hofmann
Hi Rolf,
hi Sam,
hi Bob,
many thanks for the nice words. In the mean time i am working on some parts of the roof. Here are the next photos....
Posted: Fri Nov 10, 2017 3:49 pm
by Martin Hofmann
and here are the next photos.....
