Martin's Jagdpanther
Has liked: 92 times
Been Liked: 220 times
Re: Martin's Jagdpanther
Post by Vince Cutajar » Fri Jul 05, 2019 4:14 pm
It will be interesting to see how your recoil system develops. I can see you are using a linear bearing and toothed (timing) gears. Looks to be interesting. For my Tiger 1 I will be using most of the Armortek hardware but controlled by an Arduino and a stepper motor.
Has liked: 237 times
Been Liked: 428 times
Post by Stephen White » Fri Jul 05, 2019 6:29 pm
Martin, great to see your engineering skills. There is some film footage of the Weald Foundation Jagdpanther in action in my TankFest video on the TankFest 2019 thread. (See at 5.15 mins into the video).
https://www.youtube.com/watch?v=N0yq6vpZu98
With a linear bearing, you may well have to balance the gun barrel longitudinally. I found with my Cent linear bearing that any slight axial misalignment causes the barrel to jam in the bearing. I shimmed it to make sure there was no free play in the bearing and with the gun in balance, it now recoils very smoothly and freely. I'll be interested to see your experience.
Martin Hofmann
Has liked: 7 times
Been Liked: 136 times
Post by Martin Hofmann » Thu Jul 11, 2019 5:42 pm
Hi Vince,
hi Stephen,
her you can see the next progress of the recoil system with the new motors for barrel movement.
Maybe i forgot to tell you: there are 2 linear ball bearings in the parts with an inner diameter of 20mm and a distance to each of approx. 120mm. So i am sure there is no problem of jamming, because the rod has a tolerance of 20 -0.025 mm.
Regards Martin
Has liked: 122 times
Been Liked: 36 times
Post by Christoffer Ahlfors » Fri Jul 12, 2019 8:12 pm
I realize now that in order to fully appreciate this, I would need to know what it looked like before your modifications. :?
Either way, just watching your mechanics is pure joy! :D
Martin Hofmann
Has liked: 7 times
Post by Martin Hofmann » Tue Jul 16, 2019 5:08 pm
Hi Chris,
thanks for the flowers :D :D .
Here starts the chaos of the electric with all switches and the new 60W Benedini amplifier. It has a great sound after 2 hard weeks of working with all the cables, relais, power supply, aux module and switches ...............
Regards Martin
Has liked: 92 times
Post by Vince Cutajar » Tue Jul 16, 2019 8:27 pm
A very neat layout. Can't wait to see it in action.
