John's Panzer IV no. 004
John Fitzsimons
Been Liked: 29 times
Re: John's Panzer IV no. 004
Post by John Fitzsimons » Tue May 14, 2013 12:33 am
Rear plate port cover fitted. Could be a useful place for a switch.
Forgot to add tow cable brackets. Will have to remove some zimmerit.
viewtopic.php?f=4&t=4770
John Fitzsimons
Post by John Fitzsimons » Tue May 14, 2013 12:38 am
I have made a new water filler cover to replace the block of aluminium supplied with the kit. The lid opens so I might cut through the base and deck for switch access if necessary.
phil fitzpatrick
Post by phil fitzpatrick » Tue May 14, 2013 9:24 am
Hi John
Nice work on your Panzer1V,the extra detail parts you are making
are really nice as usual.
John Fitzsimons
Post by John Fitzsimons » Thu May 16, 2013 12:29 am
Thanks Phil. A little more progress with the rear. Added the straps to the exhausts and relocated the small outlet pipe to top. Also assed the kit tow rope brackets. The tow rope is I think a bit short.
I started assembling the turret. Removed the machining marks first. Inside and out.
Like Nick I noticed that The eight M5 screw holes in the gun mount were not tapped. Neither were the M5 screw holes for attaching the turret base tapped. :cry: I hate tapping holes. No good at it. At least they were large size.
John Fitzsimons
Post by John Fitzsimons » Tue Nov 05, 2013 1:44 am
After a long break I am finally getting back to my Panzer IV.
Having first removed the front and rear sections from the one piece kit fender I am ready to add functioning mudguards. I will start with the rear.
To complete, I still need to fit a spring mechanism and reflector
Next to complete the front guards.
Iacopo Di Giampietro
Been Liked: 6 times
Post by Iacopo Di Giampietro » Tue Nov 05, 2013 7:56 am
Great work: very interesting and beautiful!
PS: be careful that the rear notek was mounted upside down ....
Been Liked: 394 times
Post by simon_manning » Tue Nov 05, 2013 8:46 am
nice work john, the detail looks good, regards simon.
John Fitzsimons
Post by John Fitzsimons » Tue Nov 05, 2013 10:14 am
Thanks for the comments.
Lacopo, i will fix the notek. Just loosely fitted to avoid loosing it.
The panzer IV mudguards are quite complicated in shape and kit part was very basic.
Worth the effort.
Been Liked: 106 times
Post by Robert E Morey » Wed Nov 06, 2013 7:06 am
John,
The rear fenders are superb! Great addition! Your brass work is excellent.
Kind regards,
Tim Bowman
Been Liked: 3 times
Post by Tim Bowman » Wed Nov 06, 2013 11:11 pm
Hi John
Your rear fender/mud flaps are PERFECT! your brass-work amazes me every time you post something new. Very nice!
best regards
John Fitzsimons
Post by John Fitzsimons » Fri Nov 15, 2013 1:07 am
Thanks Bob and Tim. I have started work on the front mudguards also. Still to add the spring mechanisms to both front and rear guards.
John Fitzsimons
Post by John Fitzsimons » Mon Nov 18, 2013 2:22 am
I am replacing kit spare wheel box with my own version in brass. also making some fender supports.
John Fitzsimons
Post by John Fitzsimons » Tue Feb 25, 2014 1:04 am
The kit cupola has many problems. I hope to fix some of them but still retain the basic cupola.
I hope to add vision port interior detail. How functional they will be is not yet decided.
First I need to replace the view port covers. Kit covers are for the bin.
Next I will make the vision block holders and clear resin inserts.
Nick Farrugia
Post by Nick Farrugia » Wed Feb 26, 2014 9:18 pm
Hi John
just been caching up on your build , looks brilliant welldone great brass work and details
best regards Nick
John Fitzsimons
Post by John Fitzsimons » Wed Mar 05, 2014 6:18 pm
Finished the rear mudguards. Added spring mechanisms. Made my own springs from steel wire. They work nicely now.
Added C hook holder. I used the kit C hooks but reshaped slightly.
